stuey Posted August 7, 2011 Share Posted August 7, 2011 My ASP 61 has been a bit leaky around the rocker cover joint, and probably through the bolt holes. I have some Hermetite Instant Gasket which I could use to seal the join and some around the heads of the bolts. It is a silicone sealant, is it suitable for such a use and if not what is good (preferably available in Halfords etc) Thanks Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted August 7, 2011 Share Posted August 7, 2011 hello again stuey......use some clear silicone.....or if you want a gasket - use some brown paper......and silicone..... ken anderson ne..1 .. 4ST dept. Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted August 7, 2011 Share Posted August 7, 2011 Why not re-surface the rocker cover on a sheet of wet & dry 600 grade maybe on a perfectly flat surface ? Don't overdo it otherwise the rockers might touch the cover ! I doubt that the actual top of the head has distorted where the rocker cover fits . I agree with Ken about the brown paper gasket if the above fails to stop leaks . In my day we used "Gasket Goo" but havn't seen it for years Quote Link to comment Share on other sites More sharing options...
