Matt Vicaradge Posted May 8, 2010 Share Posted May 8, 2010 Hi All, This is my first post and I'm looking for some advice on prop selection. I have an Art-tech Corsair with a nasty 3 bladed prop that makes belly landing seem a bit dodgy, I have no idea what size 2 blade to fit instead and how this will affect the power train, Has anyone done anything similar? Or can anyone offer some wisdom on the matter? It would be greatly appreciated, Thanks, Matt. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 8, 2010 Share Posted May 8, 2010 What size is the 3 bladed prop Matt? Quote Link to comment Share on other sites More sharing options...
John Privett Posted May 8, 2010 Share Posted May 8, 2010 Matt, as a rough guide, add an inch to the diameter when switching from 3 to 2-bladed props. And conversely if you need to replace a 2-blade with a 3-blade then go down an inch on diameter. Pitch should stay the same. Quote Link to comment Share on other sites More sharing options...
Matt Vicaradge Posted May 9, 2010 Share Posted May 9, 2010 Hi, thanks for the info. The Prop got smashed to atoms and thrown away last summer following the "accident" I've only just started to think about a repair job. The websites that stock this plane tend to be a bit light on technical details like prop size and motor power and esc ratings and pretty much any other useful info you may need. Still I can't bring myself to buy a mainstream trainer when I can get this back in the air for a few quid! Thanks again for the advice, I shall continue to trall the net for the prop size. Quote Link to comment Share on other sites More sharing options...
Matt Vicaradge Posted May 9, 2010 Share Posted May 9, 2010 I've been doing some digging and it seems I had a 11x6 so I guess I'll try out a 12x6 I also found the following site; http://www.mh-aerotools.de/airfoils/propuls2.htm This seemed to agree with what's been said here. Thanks again. Quote Link to comment Share on other sites More sharing options...
Roberto Gava Posted May 9, 2010 Share Posted May 9, 2010 I can't follow the link. There is anything wrong? Or it is my explorer. Quote Link to comment Share on other sites More sharing options...
Matt Vicaradge Posted May 9, 2010 Share Posted May 9, 2010 Dont Know, It seems to work when I use it, I'm using Chrome. Its basically some calcs on power and prop sizing with formulas to convert from a 2 bladed prop to a 3 or 4 bladed. Quote Link to comment Share on other sites More sharing options...
Roberto Gava Posted May 10, 2010 Share Posted May 10, 2010 For this I use Extended Prop Selector software. In my experience, I'm not shure of the figures of consumed power against declared power of most IC engines. I tend to believe that declared power data are very optimistic. Once I asked Thunder Tiger technicians by mail and they answered me that they declared power figures on 15% nitro fuel, low oil percentage and small props to get the engine into its high revs band. For example, they declare 1.4 Ps on a PRO .46 and this engine, with a 11x6 prop gets usually about 11500 rpm, that according to the calculations of the software is around 0.71 Hp. Quote Link to comment Share on other sites More sharing options...
John Privett Posted May 10, 2010 Share Posted May 10, 2010 Roberto, the magazines used to include a power-curve chart with engine reviews. These always showed that maximum power was developed at revs far higher than were commonly used - at least in Europe. Maybe the Americans, with fewer noise-sensitive sites, used smaller props to get more revs, power (and noise) from their engines? Quote Link to comment Share on other sites More sharing options...
