Myron Beaumont Posted October 14, 2011 Author Share Posted October 14, 2011 Doug re ;- "Go on Myron ,rub it in" OK ,if you insist ! We have several fields and am planning more than one runway actually ---Just so that I can enjoy a change of scenery and cope with different wind directions.One by the river would be nice whilst fishing at the same time ,maybe after a ride on Dobby or Betty .The sheep have kept most of the grass down to a couple of inches this summer but most are off to market today so I shall maybe have some dosh to buy a nice gas turbine . ( I can't access the smileys today but I thought I'd "rub it in " --Just for you .LOL.) Final thought ---Don't need silencers on my engines here-Good for scaring off crows !! Myron YO13 Take with a small pinch of salt dept. Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted October 14, 2011 Author Share Posted October 14, 2011 I think I have the answer to "to coil or not to coil". Nobody seems to have mentioned mounting the retract unit on rubber grommets! What do you think ? It would,I think,at least protect the wing mountings & associated structure .Not too soft & not too hard .Maybe a sliced up pencil rubber would be a good starting point ? Myron .(Don't want to wait up to 45 days for delivery by HK alternatives dept. for their legs ) Quote Link to comment Share on other sites More sharing options...
James40 Posted October 14, 2011 Share Posted October 14, 2011 The trouble there is, you'd have to bolt the u/c mounting to the wing spar so tight to prevent a sloppy leg that the rubber bush would no longer be providing any protection. For that type of mounting to work, it would have to be like an engine mount with the bushes built in, and even then the bushes would have to be pretty stiff to prevent flex and movement of the leg or you will have some interesting ground handling! The oleo leg is the way to go, probably why just about all real aircraft have them, it's just a shame they are expensive and carry a weight penalty. Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted October 14, 2011 Author Share Posted October 14, 2011 James Yep,point taken,especially since the bearers are at an angle to the wing centreline .By the way ,I forgot to mention that all my coiled struts have bent above the coil on a heavy landing,especially the nose wheel on a trike arrangement,hence my original question I have been searching on the web all morning for a quick delivery outlet of the123mm legs I need .No luck so far (hadn't noticed the HK small print mentioning up to 47 days delivery ) GC is not answering the phone at the moment .Busy I expect. Myron Quote Link to comment Share on other sites More sharing options...
Pete B Posted October 14, 2011 Share Posted October 14, 2011 Myron,HK always says up to 45 days - but in the vast majority of cases it takes between 5 and 14 days. The Himodel order I put in took about 10 days, that's all. Just seen these 5mm legs in stock at GC - could be ideal. Pete Edited By Pete B on 14/10/2011 16:43:04 Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted October 14, 2011 Author Share Posted October 14, 2011 PeteB Yep ,spotted those but too long if I have correctly guessed the pivot point of the retract unit . 123mm seems about right but won't know for sure until they arrive .Been a week now Myron YO13 frustrated legless dept. Quote Link to comment Share on other sites More sharing options...
Lazygit Posted October 14, 2011 Share Posted October 14, 2011 I put 8swg oleos on a 3lb model. They still get damaged from less than perfect landings. Quote Link to comment Share on other sites More sharing options...
