Stephen Grigg Posted December 30, 2011 Share Posted December 30, 2011 Great to hear your Back Tony,you have had a good break.Hope youve returned revtalised ,do you have any planned builds for 2012.Look forward to your futre posts on this fascinating thread,A buils of 4 Hurricanes goodness me you must be a good anfd fast builder.Good luck on your Multi build thread. Quote Link to comment Share on other sites More sharing options...
wayne drinkwater Posted December 30, 2011 Share Posted December 30, 2011 They look awesome I have always planned to build one of those beauties I frequently grab the plans and look at them ,i think the Hurricane a far prettier shape than the spit. I have to finish my Airsail Auster first though Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted December 30, 2011 Author Share Posted December 30, 2011 sat outside before the rain started and sanded this down to shape.only 3 to go. made a start on the center section of 1 main wing as well.lots of ribs to cut out to make 4 . Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted December 30, 2011 Author Share Posted December 30, 2011 number 1 center section under construction. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted December 30, 2011 Share Posted December 30, 2011 Pleased to see youve got yourself back into the swing of things Tony hope everything works out over night Quote Link to comment Share on other sites More sharing options...
Adrian Day Posted December 31, 2011 Share Posted December 31, 2011 Hi Tony B loving the fantastic workmanship and how your doing 4 at same time thats some skill.. can i ask what wood your using for the ribs , is it ribstock of do you just use standard balsa?? also where you get your supplies?? quality work will be keeping a close eye this one best wishes for new yearAdrian Quote Link to comment Share on other sites More sharing options...
Andy Anscombe Posted December 31, 2011 Share Posted December 31, 2011 happy new year Tony Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted December 31, 2011 Author Share Posted December 31, 2011 i am building 3 as per plan using liteply for the wing ribs.mine is being built using as much balsa as pos as a weight saving experiment.so far i have saved 120gms on the fuselage, 30gms on the horizontal stab.the center wing section is 24gms lighter so far. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted December 31, 2011 Author Share Posted December 31, 2011 number 1 center section nearly done.number 2 under way. oh well back to cutting wing ribs. Quote Link to comment Share on other sites More sharing options...
Adrian Day Posted January 1, 2012 Share Posted January 1, 2012 wasnt sure if you was using balsa for all ribs ply takes a lot more time to make i would guess? .. thats work in the frist degree .thats some saving from the other models . like everything so far sorry to ask just designing a model at mo and not sure how to design the wing.. its kind of like the edge style wing so working on the fixings and rib design .. nothing as good as your work thanks for your reply and good luck for the build Adrian Quote Link to comment Share on other sites More sharing options...
Seamus O'Leprosy Posted January 1, 2012 Share Posted January 1, 2012 Are you still enjoying yourself?I don't even like building two wing panels that are the same! Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 1, 2012 Author Share Posted January 1, 2012 some days it can be a bit boring, cutting rib after rib after rib after rib after rib.then having to do it again for the next one.i tend to do a bit of cutting then build something to break the monotony.be glad when its over though.i got more to build waiting in the wings. mind you i love building, the feeling of immense pride and satisfaction when you look at what you built from nothing.the flying side does not do much for me really. Quote Link to comment Share on other sites More sharing options...
Andy Anscombe Posted January 1, 2012 Share Posted January 1, 2012 its much appreciated Tony and I admire your persistent and patiance it makes a good read to building thanks Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 1, 2012 Author Share Posted January 1, 2012 center section 1.center section 2 almost ready to come off of the plan.then we start number 3. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 2, 2012 Author Share Posted January 2, 2012 center section 1 jammed in placenumber 2 nearly therenumber 3 on the plannumber 4 still having the ribs cut. mad me! naaaaaaaaaaaaaaaaaaaaaa Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 2, 2012 Share Posted January 2, 2012 The flying side is cos your no good at it to impatient and wrong model choice.Once we get to have a session with the Swift youll be fine and see a direction to go.Thoroughly enjoying the build and the build and the build and the build and its a massive task you volunteered your self 4(dyou get it 4 ) oh hahaha,Watching a build blog is always interesting Watchingsomeone build 4 at the same time is amazing .I feel you are still goinf faster than some people who are building 1 model You should be very proud of your ahievement so far.Im amazed at how much youve done on these 4 builds in the time thats elapsed. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 2, 2012 Author Share Posted January 2, 2012 hmmmmmmmmmmmmmmmwhat are you after stephen. Quote Link to comment Share on other sites More sharing options...
Del Wheatley Posted January 3, 2012 Share Posted January 3, 2012 Posted by Tony B on 02/01/2012 23:02:09: hmmmmmmmmmmmmmmmwhat are you after stephen. Number 5 Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted January 3, 2012 Share Posted January 3, 2012 No Del one of them is mine,Ive already given Tony my electric power set,mines a lightened version no glue Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 3, 2012 Author Share Posted January 3, 2012 r/h wing panel started. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 3, 2012 Author Share Posted January 3, 2012 hurripains in numerical order from left to right. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 3, 2012 Author Share Posted January 3, 2012 trial fit. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 4, 2012 Author Share Posted January 4, 2012 wing number 1 joined and trial fit.next job is to make 3 more l/h wing panels, then turn the tracing over and do 4 r/h's. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 5, 2012 Author Share Posted January 5, 2012 wing 1 and wing 2. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 6, 2012 Author Share Posted January 6, 2012 where we are todaywing 1wing 2 half builtwing 3 l/h panel and center section. wing 3 r/h panel is on the board. Quote Link to comment Share on other sites More sharing options...
