andy willis Posted January 27, 2012 Share Posted January 27, 2012 hi all i just bought Eg mxs-r 25% 75" wing span lovelly looking model matt hall colour scheme, just bought Crrc pro 26 cc petrol engine has anyone had experience with this engine and also am using spektrum radio gear with savox torque servos anyone recommend the right battery which works well with this format as i will be doing bit of 3d and sport thanks andy Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted January 27, 2012 Share Posted January 27, 2012 I've got 2 CRRC 26's. One mk 1 and one Mk2, with the beam mount. I'd recommend a 6v battery on the receiver and servos, and 4 cell on the ignition. Don't use 6v on ignition, as they tend to fry! For safety, on my larger models, I use two battery packs through a Powerbox dual switch, which keeps supplying power, if one battery fails/shorts out. Peace of mind. Quote Link to comment Share on other sites More sharing options...
BB Posted January 27, 2012 Share Posted January 27, 2012 Couple of Sub -C A123 type battery linked through a matchbox or similar should be fine. Savox all round will draw some power. CRRC 26 v2 (if it is) is an ok engine. Slightly down on power to a Zenoah,MVVS equilvelant. No standard clunk in the tank, go felt. Oh, Take the ratchet off your throttle stick if you haven't already. Aids 3d'ing. Eagle Tree battery backup Battery SMServices CRRC bits n'pieces Am sure better folk than me will be along with better and more comprehensive advice Edited By BB on 27/01/2012 19:03:37 Quote Link to comment Share on other sites More sharing options...
andy willis Posted February 16, 2012 Author Share Posted February 16, 2012 Thanks all got all set up thanks for for the advice just having bit problems with crrc 26 v2 engine cable will not reach the cam the way the design of aircraft and the choke has a strange set up. With no servo any advice Thanks guys Quote Link to comment Share on other sites More sharing options...
