Myron Beaumont Posted March 28, 2012 Share Posted March 28, 2012 Would you file away a flat on the aluminium oleos or off the plastic on the retracts to enable the darn things to close properly ? It's about 5 degrees that is interferring with the retraction being complete Quote Link to comment Share on other sites More sharing options...
Alan Cantwell Posted March 28, 2012 Share Posted March 28, 2012 can the slot the oleo fits in not be widened/ deepended? i woudnt file the retracts at all, unless there is enough material available and pictures? Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted March 28, 2012 Author Share Posted March 28, 2012 Alan There isn't a slot as such in the retracts meant for wire u/c s ,it's a flat surface that the oleos I have bought are slightly too big in diameter to close up against .Only a matter of maybe twenty five thou in old money .Reckon I'll just file away a sliver of plastic after what you've said .The oleos cost more than tbe retracts by the way ! Thanks Myron Quote Link to comment Share on other sites More sharing options...
GrahamC Posted March 29, 2012 Share Posted March 29, 2012 Myron, I think I mentioned this issue to you a while ago. The HK retracts are providing Stirling service on my Spitfire, and I'm very pleased for the money. I wouldn't touch them! I had the giantcod oleos which didn't fit for the reason described. I got some more slender oleos from the guys at gliders in Newark, which were exactly the right size for a 62.5 inch Spit. The giantcod oleos went on eBay and were snapped up on a buy it now for what I payed in less than an hour. I noticed that when I bought them on giant cod there was very little information about dimensions, so I put them on a pice of paper', marked up all the dimensions and used a photo of the leg on the dimensions in the listing. The one I bought were about £8.50 each and are available as ripmax spares so your LMS should be able to get them. They are the ones that come with the Sky RC kit here. Edited By GrahamC on 29/03/2012 07:42:35 Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted March 29, 2012 Author Share Posted March 29, 2012 Graham Thanks for the reply.I did buy the oleos from Newark actually not GC ! I'll double check that I've got the right ones later today when my brain cell gets into gear . Myron. Quote Link to comment Share on other sites More sharing options...
GrahamC Posted March 29, 2012 Share Posted March 29, 2012 Hmm. very odd! - I'm manic today work wise - but when I get a moment I'll try and get a few dimensions off my legs. (That would sound very odd read out of context!) - I take it you have got the larger HK retracts - the ones rated for 4.5kilo? Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted March 29, 2012 Author Share Posted March 29, 2012 Graham Just found the labels .The retracts are HKD-514's and the oleos Z-SKYRE0303 . Anyway ,on closer examination ,I reckon all will be OK if I remove the joining flashing on the two halves of the retract casing against which the oleo sits. A perfect fit should then be possible . Thanks again .Should have gone to specsavers .Fingers crossed ! Quote Link to comment Share on other sites More sharing options...
