cymaz Posted April 11, 2012 Share Posted April 11, 2012 Dear All I have a 25A 2v battery, 20amp immersion heater switch and fuse. 2 core cable and a glow clip. All this works fine and there is no overheating etc. What I would like to know is where would I put a volt meter in the circuit so it will only read when the glow clip is on and heating up the plug. This is the type of volt meter I have Quote Link to comment Share on other sites More sharing options...
Peter Beeney Posted April 11, 2012 Share Posted April 11, 2012 cymaz, With respect, but can I ask if you want to use the volt meter to indicate that your glow plug is glowing, or not? I only ask because the voltage at the glowplug with a fixed 2 volt source is going to be relatively unimportant. PB Edited By Peter Beeney on 11/04/2012 11:29:44 Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted April 11, 2012 Share Posted April 11, 2012 The voltmeter should be connected accross the glow clip I would think. NOTE: Connected here it will read whenever the switch is on, irrespective of whether the clip is on the glowplug or not. It is more usual to use an ammeter in series with the circuit, that way you can tell if current is actually flowing through the plug. If the plug is blown, then no current will flow and the ammeter reads zero. You may be able to tell with a voltmeter, the voltage is likely to be a little lower when powering a good plug, than when not connected to a plug. Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 11, 2012 Author Share Posted April 11, 2012 Better get an ammeter then?? Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted April 11, 2012 Share Posted April 11, 2012 a 5A ammeter would be fine, 3A is a pretty normal current for a glow plug, something like this Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 11, 2012 Author Share Posted April 11, 2012 Great, thanks. I suppose there is a + and - to the ammeter Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted April 11, 2012 Share Posted April 11, 2012 Yep theres a + and - get it the wrong way and it will try to go backwards. Make sure it's in series too, connected accross the battery it will short it out and probably let out a little smoke... Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 11, 2012 Author Share Posted April 11, 2012 Considering I have a 25A battery then I sould really get a 25/30A meter Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted April 11, 2012 Share Posted April 11, 2012 Hi cymaz, no, there is no need for a bigger ammeter, if you are only using it to check the plug current. As Chris has said, it must be connected in series. Cheers Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted April 11, 2012 Share Posted April 11, 2012 Yes, the problem with a 25A is that you wopn't be able to read it easilly at 3A, get above 5A and the glow plug will behave as a fuse................. Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 11, 2012 Author Share Posted April 11, 2012 OK . Just ordered one thanks Quote Link to comment Share on other sites More sharing options...
