spoddy d.s.t Posted December 8, 2007 Share Posted December 8, 2007 Just hoping someone might know which battery pack i need for theFUTABA 4 CHANNEL RADIO CONTROLLER 4EX 40MHz FMIt takes 8 aa's at the moment.And if so how does plug in ThanksDave Quote Link to comment Share on other sites More sharing options...
Colin Hostler Posted December 8, 2007 Share Posted December 8, 2007 Dave there`s a flat pack available with a short lenght of wire and a futaba plug on the end which plugs into your tx.If you look in the batt compartment you`ll see a hole which is the futaba shape and pins to receive the plug.Try Overlander and proberbly any model shop. Good Luck.Colin. Quote Link to comment Share on other sites More sharing options...
spoddy d.s.t Posted December 8, 2007 Author Share Posted December 8, 2007 Cheers Colin.I have seen lots of different flat packs with all different no's on them,some really cheap on ebay,but wasn't sure of the plug so i didn't buy.I have a hole to the left of the tx,at the moment theres a plug in there with red and black wires.Do i just unplug this then and plug the new pack there Colin?(when i get it)Dave Quote Link to comment Share on other sites More sharing options...
Colin Hostler Posted December 8, 2007 Share Posted December 8, 2007 Correctum,as you`ll see the plug is futaba style so you can`t get it wrong(famous last words)Colin. Quote Link to comment Share on other sites More sharing options...
spoddy d.s.t Posted December 8, 2007 Author Share Posted December 8, 2007 Many thanks ColinDave Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted December 9, 2007 Share Posted December 9, 2007 Spoddy, shoot me down if I'm teaching you to suck eggs but you know 40MHz is for (surface) RC boat and car use? - not planes. OK, I'm going in.. Quote Link to comment Share on other sites More sharing options...
spoddy d.s.t Posted December 9, 2007 Author Share Posted December 9, 2007 I definitely wouldn't shoot you down mate.The 40 is for my bait boat,and its eats those aa's.Pull up pull up,best to be safe though David i would image other newcomers to flying wouldnt know.Dave. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted December 9, 2007 Share Posted December 9, 2007 Thanks Dave....or retailers...we had a little helicopter sent in recently that was 40MHz, we sent it back with a nice little note Quote Link to comment Share on other sites More sharing options...
spoddy d.s.t Posted December 9, 2007 Author Share Posted December 9, 2007 I got my 40MHz off EBay from china and the instructions are all aimed at plane use.so somebody somewhere must be using them for planes.Is it just the UK where they are restricted to ground use? Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted December 9, 2007 Share Posted December 9, 2007 Don't honestly know Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 9, 2007 Share Posted December 9, 2007 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
The real Ron Truth Posted December 10, 2007 Share Posted December 10, 2007 the range of those cheapo models is very low, less than 50 metres for some. Its only illegal as it clashes with other recognised frequency users and wont crash a model on 35mhz. Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 10, 2007 Share Posted December 10, 2007 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Evan Pimm Posted December 16, 2007 Share Posted December 16, 2007 40 mHz is used specifically for aircraft way downhere in NZ, cause that what the domestic Japanese market uses. So I guess it's just the Brits that restrict 40 megs to surface only... but then we can use any freek from 27 to 72 meg for anything we like, with the provisio that 40 is used for aircraft only. That way you can come down here on 35 and still use your gear, and get xtals etc. We have a few on 72, again cause thats what the Yanks use, so Fubaba and JR make lots of 72 meg sets and it makes no sense not to use them as well... but I guess we are far enough away not to cause any interference.Evan. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted December 16, 2007 Share Posted December 16, 2007 Are you using 2.4GHz in NZ yet Evan? Quote Link to comment Share on other sites More sharing options...
Evan Pimm Posted December 16, 2007 Share Posted December 16, 2007 Yes, both the Spektrum sets are available, and the various module updates from the major manufacturers to convert their mainline sets. I have to say, that apart from a couple of 'park flyers', there hasn't been that much of an uptake of the 2.4 stuff. Most people are quite happy with there present gear.Evan. Quote Link to comment Share on other sites More sharing options...
David Martin 2 Posted December 21, 2007 Share Posted December 21, 2007 Probably out of date now David, but I've fitted 8 off green 'Instant' 2100mah AA Nimh cells to my Twister heli Tx and haven't had to charge them since September mate, still well up on the scale..! The advantage of Instant cells is that they have a very low self discharge rate (about 15% of their capacity over a year) and are always ready to use. No need to charge and use soon after like the normal Nimh cells used, mine were ready straight from the carry case they came in (like when you buy Duracells).Good value too at £4.50 for 4 I thought. Just make sure and put a very light smear of vaseline on the terminals before you fit them to save any corrosion. Especially if you're using a bait boat around salt water areas. You can plug in the supplied Tx charger into the TX jack socket to charge them in the normal way, but if it's a 50mA charger, you may just have to leave it to charge for a couple of days from flat. I will use a Prodigy cut off charger at 200mA for mine.http://www.component-shop.co.uk/html/instant.htmlThey do Sanyo cells too for a little more. I always use welded packs in my Tx/Rx for all my planes/helis I use outside, more peace of mind than the sprung connection to the cells in dry sets. Saying that, I used a dry fit ACOMS 2 ch Tx on my Rough rider buggy for years without ever having an o/c occur between cell terminal and Tx. Good luck with the fishing, I don't use a bait boat for the trout, sometimes wish I did though..! Quote Link to comment Share on other sites More sharing options...
