Frazer Simpson Posted May 6, 2012 Share Posted May 6, 2012 I have shaped the tailplane as suggested and it looks really good now. I have reached a stage where I need to purchase the servos. I’m completely bewildered by huge range available. If someone would kindly advice me what servos I need for what function on the Tailwind I would be most appreciative. I’m leaning towards a Futaba transmitter’ Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted May 6, 2012 Share Posted May 6, 2012 Frazer, Any 9gr servo size will do just fine , Iam using them for all the control surfaces. For elevator and Rudder /steerable tail wheel Iam using the metal gear type. Have you seen my build blog of the Tailwind with lots of pics. tailwind Ton Edited By Ton van Munsteren on 06/05/2012 10:59:55 Edited By Ton van Munsteren on 06/05/2012 11:05:03 Quote Link to comment Share on other sites More sharing options...
Frazer Simpson Posted May 6, 2012 Author Share Posted May 6, 2012 Hi Ton Thanks for the advice; I wouldn’t have had a clue what to buy without you help. Yes I have just discovered your wonderful blog and it’s given me a fresh impetus. I don’t think I could build this plane without it. Thanks for sharing your vast knowledge with people like me. Regards Frazer Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted May 6, 2012 Share Posted May 6, 2012 Hi Frazer, Good to be of help, if you have any question please ask I will help as good as I can. Ton Quote Link to comment Share on other sites More sharing options...
Frazer Simpson Posted July 13, 2012 Author Share Posted July 13, 2012 I see on the wing plan is says, Add 2" washout between last R3 and tip. Where is this measurement please, I'm stumped yet again. You help will be much appreciated>> Quote Link to comment Share on other sites More sharing options...
Frazer Simpson Posted July 23, 2012 Author Share Posted July 23, 2012 II see on the wing plan is says, Add 2" washout between last R3 and tip. Where is this measurement please, I'm stumped yet again. Your help will be much appreciated. I posted this query before and as I didn’t get a reply I thought I either sent to the wrong blog or perhaps it’s so obvious I should be able to work it out for myself. I really don’t understand this note can anyone please help. Apart from that its coming along nicely. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted July 23, 2012 Share Posted July 23, 2012 It does not say 2 inches washout. It says two degrees washout. THis means raising the trailing edge of the tip rib by about 3/32" to an 1/8 while the wing is flat on the board. This puts a slight twist in the tip. Quote Link to comment Share on other sites More sharing options...
Frazer Simpson Posted July 24, 2012 Author Share Posted July 24, 2012 Thanks Peter Now I have look really close at the drawing I can see its degrees. I have the drawing pinned to a wall about 15” away from where I work and from that distance it looked just like the inches sign to me. Do I feel daft, Now you have explained what a washout means I will never make that mistake again. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted July 24, 2012 Share Posted July 24, 2012 WE all have to learn. I am still learning. Quote Link to comment Share on other sites More sharing options...
