NewBuilderFlyer Posted May 19, 2012 Share Posted May 19, 2012 I'm building a Harlequin and am about to fit the engine - in my case it is a SC 0.32 two-stroke. I've bought a resin mount which has two arms that protrude about 2.5 inches from the front plywood former. The 0.32 is quite small and I'm wondering where to position it along the mount. I think it should go as close to the firewall as possible so that it's rigid - is that correct as I've not seen any mention of the optimum place to mount it? Quote Link to comment Share on other sites More sharing options...
Alan Cantwell Posted May 19, 2012 Share Posted May 19, 2012 isnt there a cowl on this model? Quote Link to comment Share on other sites More sharing options...
NewBuilderFlyer Posted May 19, 2012 Author Share Posted May 19, 2012 Not a ready made one - there are instructions in the RCM&E article about mounting the engine and then making the cowl around it. Quote Link to comment Share on other sites More sharing options...
Philip Ogden Posted May 19, 2012 Share Posted May 19, 2012 Normally, a distance from the firewall to the prop. driver face would be quoted. Assuming you have some flexibility, I would leave mounting the engine till last,then position the engine to achieve the correct balance without having to add more lead than necessary. Then simply build the cowl around that. Edited By Philip Ogden on 19/05/2012 21:55:47 Quote Link to comment Share on other sites More sharing options...
Alan Cantwell Posted May 19, 2012 Share Posted May 19, 2012 take the measurement from the bulkhead to the spinner off the plan, and mount the engine to that, once the engine is on the bulkhead, it will become torsionally stiff, no probs Quote Link to comment Share on other sites More sharing options...
NewBuilderFlyer Posted May 19, 2012 Author Share Posted May 19, 2012 ok - I've measured from the plan and that looks just right. Thanks for all your helpful replies - another bit of knowledge I can store away. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted May 20, 2012 Share Posted May 20, 2012 hello NBF.....leave enough room for the fuel pipes to come through comfortable..... ken anderson ne..1 ..fuel tube dept. Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted May 20, 2012 Share Posted May 20, 2012 Hi NBF.....if you are not restricted by a cowl then as close to the firewall as possible but as The Great Kendo points out leave enough room for the fuel tubes.... Quote Link to comment Share on other sites More sharing options...
