First Turbine Model? Kits Available?
Garbo
  • 1 month later...
Garbo,
Maybe the RBCkits Thundertail is something you like checkout the site there is also a video.
Thundertail
Or maybe the following model my de design for Turbine, but only made it to an prototype to fly but never made it to a kit.
It was designed in 2006 but who knows I could make it in to a RCME free plan some day.
span 157cm
length 134cm
weight 3,2 kg empty (without fuel)
Ton
Build anything you like and can afford. I've got one, though don't fly it often as it is not allowed at Beaulieu. There is nothing difficult building a turbine model, or flying it, no more so than a glow or electric model. They land a bit fast. You don't need a 'turbine trainer', if you are competent flyer you can fly most things.
I looked at Nijuis' Vampire. Excellent value for the whole thing. But a bit big and heavy, engines of the size required are expensive too. You might not think so at a quick look, but in effect you have joined the LMA if you build it smiley
Ton,
your effort looks much nicer than the Boomerang. Can we have a plan?
Edited By Mark Powell 2 on 20/08/2012 19:55:35
