Nickaliath Posted November 5, 2012 Author Share Posted November 5, 2012 Anybody? Quote Link to comment Share on other sites More sharing options...
Nickaliath Posted November 5, 2012 Author Share Posted November 5, 2012 Couple of update images attached with parts tried up to each other. Got most of the retract air lines and fittings in the wing assembly. Found that i have trimmed the canopy edge lip off too much! But on the flip side should be able to make it look more realistic this way. Edited By Nickaliath on 05/11/2012 21:33:30 Quote Link to comment Share on other sites More sharing options...
Concorde Speedbird Posted November 5, 2012 Share Posted November 5, 2012 Lovely! When those tips go on that Spitfire shape will look brilliant as always! I would not fix the wing on on a model of this size, you need access to the inside. CS Quote Link to comment Share on other sites More sharing options...
Nickaliath Posted November 6, 2012 Author Share Posted November 6, 2012 Whats the opinions on a clipped wing version? like the later spits.? Quote Link to comment Share on other sites More sharing options...
Concorde Speedbird Posted November 6, 2012 Share Posted November 6, 2012 If you like it, then you can but I personally think that Spits look best with the full elliptical wing. CS Quote Link to comment Share on other sites More sharing options...
MikeS Posted November 6, 2012 Share Posted November 6, 2012 I would keep the wings off. Making it as one may cause problems for you if you have a crash, let alone if something goes wrong and have to rip it apart to make a repair. But it is looking very nice. Quote Link to comment Share on other sites More sharing options...
Shaunie Posted November 6, 2012 Share Posted November 6, 2012 Nice build! I have one of these (unbuilt) in the loft ,complete with engine, spinner, retracts and wheels. It was a gift from a friend who bought it and decided not to continue with modelling. Seeing this build has given me the bug to start on it! I haven't done a kit build since about 1992 but I had a count up, I have built 8 planes so far. Just don't want to start until I can do it justice. The engine I have been given with it is an RCV91CD which hopefully should be a good match. Look forward to more posts. Quote Link to comment Share on other sites More sharing options...
Nickaliath Posted November 7, 2012 Author Share Posted November 7, 2012 I have decided to keep the wings seperate & also have the original spit wings Shaunie - when you start building make sure you start a build thread, I enjoy looking at other topflite spitfire builds Quote Link to comment Share on other sites More sharing options...
Nickaliath Posted November 7, 2012 Author Share Posted November 7, 2012 What weight fibreglass do people tend to use? I was thinking of using a couple layers of fibreglass tissue? Quote Link to comment Share on other sites More sharing options...
Steve B Posted January 31, 2013 Share Posted January 31, 2013 Hello Nicka, nice buils so far! i'm a newbie too and have just started the 'a beginners p51 thread... i'll be keeping an eye on yours mate... as i said..looking good Quote Link to comment Share on other sites More sharing options...
Nickaliath Posted February 18, 2013 Author Share Posted February 18, 2013 good luck with p51 Sorry for lack of posting recently, Ive been waiting for better weather to get outside and continue build Quote Link to comment Share on other sites More sharing options...
Nickaliath Posted March 12, 2013 Author Share Posted March 12, 2013 Hello all, As i had a day off today, I managed to get a bit done on the build. Got the cowl mountings fitted and cowl fitting better. Made a mounting up for the servo that controls the air valve on the retract setup. Need to get some fuel proof paint, if anyone can recommend a supplier in UK. Quote Link to comment Share on other sites More sharing options...
Major Posted March 13, 2013 Share Posted March 13, 2013 Hi mate. Good build so far. As to the fuel proofer, check http://balsamart.co.uk .They have quite good selection, I'm sure you will find something. I personally used just Aerokote - two part fuel proofer and could recommend it. Just remember to add a little more catalyst than is says on the label. Cheers Tom Edited By Major on 13/03/2013 16:12:44 Quote Link to comment Share on other sites More sharing options...
Glen Posted March 20, 2013 Share Posted March 20, 2013 Hi All I am also new to RC Aircraft build and to the forum i am building a sig Kavalier trainer from balsa kit first but have purchased a Tony Nijheus Hurricane kit and have a large pile of balsa to sought out i have posted some pictures as i go along I am enjoying every minute but like you have to take my time best of luck Glen Quote Link to comment Share on other sites More sharing options...
AlexJ Posted March 31, 2013 Share Posted March 31, 2013 Hi there, The glassing of the air frame will need some very light cloth, 25gm/m2 and not too much resin. The resin is quite critical for an easy life, try this stuff, it is quite thin epoxy (don't use polyester) and it will not leave a waxy surface. This outfit do some very authentic paint too, although I understand it does need fuelproofing now. Good luck Alex Quote Link to comment Share on other sites More sharing options...
Dave Russell Posted June 25, 2013 Share Posted June 25, 2013 Any more news on this build.I have just bought the same kit and also this is my first one for over 30 years. Quote Link to comment Share on other sites More sharing options...
Nickaliath Posted June 25, 2013 Author Share Posted June 25, 2013 Hello, Yeah it is still on going although i havent done much on it for a while. I am intending to do a bit more on it this weekend. Quote Link to comment Share on other sites More sharing options...
Ortho10 Posted June 28, 2013 Share Posted June 28, 2013 Hi Nickaliath I'm currently building one of these myself, and we are just about at the same stage. I have a thread going on RC groups in the glow to electric conversion section. having just finished sheeting the top of my wings I can offer you some advice if required. phil Quote Link to comment Share on other sites More sharing options...
Former Member Posted June 29, 2013 Share Posted June 29, 2013 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Nickaliath Posted June 29, 2013 Author Share Posted June 29, 2013 Hello, Yeah any advise is more than welcome I had the idea to mount in wing section from another topflite spitfire build i was watching. Thought it would distribute weight better. Does anyone have any idea how long the pressure stays in the tank for on the air retracts? The way mine works it leaks a small amount of air every time its operated through the switch valve. Edited By Nickaliath on 29/06/2013 11:54:38 Quote Link to comment Share on other sites More sharing options...
Nickaliath Posted July 7, 2013 Author Share Posted July 7, 2013 Hello all, had a change on decision with powering the spitfire! decided to know go with electric power. Any recomendations and set ups would be good. Thanks Quote Link to comment Share on other sites More sharing options...
Concorde Speedbird Posted July 7, 2013 Share Posted July 7, 2013 Nice to hear from you with build progress, I am soon to start a Spitfire myself, Cambrian one. Shame to hear you are going for electric, no Spitfire character! Keep on building her with pictures. CS Edited By ConcordeSpeedbird on 07/07/2013 22:55:26 Quote Link to comment Share on other sites More sharing options...
David Free Posted September 2, 2014 Share Posted September 2, 2014 Looking great, think I will have to get one of these kits, really fancy one. And you can't beat the spitfire looks imo, also my wife,s Grandad flew one in the war so will have to find out his flight numbers and do a replica How much does the kit go for? Quote Link to comment Share on other sites More sharing options...
