Home Build Electric Motor
Tim Cheal
My son is completing an EPQ for his A levesl and has decided to build a powered aircraft. The project needs to be his own design and use a 'motor' that is homebuilt. I can work with him on the airframe design etc but he is looking for an electric motor that can be built from a kit.
Anybody know of such a kit we could purchase to power a small (say 40 inch) RC aircraft?
Tim
It's not very clear if they are kits or pre-built and if kits they may be for a very high Kv unsuitable for a conventional F/W model. Mind you, researching and documenting his own wire spec. to wind a lower Kv version might go down well...a call to the company might be useful.
Edited By Martin Harris on 23/07/2012 14:23:59
It's extremely clear:
"Each kit contains the following parts:
  • Assembled stator constructed from laminations with powder-coated inner surfaces to prevent winding shorts
  • Gold Electro-coated Rear Housing/Bearing Tube assembly
  • High-speed shielded ball bearings
  • Rotor assembly with gold electro-coated front housing, black electro-coated flux ring, and pre-installed motor shaft with retaining collar
  • Cross style aluminium backplate mount with mounting screws (not HK motors)
  • Complete set of curved NdFeB motor magnets
  • Heat shrink tubing to cover motor leads and provide strain relief
To complete the kit, the builder needs to:
  • Wind and terminate the stator
  • Glue the stator in place on the bearing holder
  • Install the bearings into the bearing holder
  • Glue the magnets into the flux ring
  • Install the completed rotor assembly onto the bearing assembly and secure the shaft with the retaining collar."
  • There are links through to the motors showing different kV ratings, so you just need to find out the windings required.
    All the motors are around the 100-200w mark at 11.1v, which would be perfect for a 40" model.
Edited By Simon B on 23/07/2012 16:24:22
Simon, what I couldn't decide was whether what they had in stock (very limited and probably unsuitable for the application described) were the kits or the pre-built versions (as suggested by the description on the page that linked to the HK versions they had in stock) - hence the suggestion for Tim to give them a quick call...sorry if I didn't make that clear.
Edited By Martin Harris on 23/07/2012 17:05:57
Thanks all for your very helpful and speedy responses.
I have just tried to call Micron Radio Control but was not able to speak to anyone. I shall try and get hold of them tomorrow to see if they have any kit versions.
Your help greatly appreciated, along with any other ideas if anybody else has any.
I wasn't sure what size either, but the 200w sounds like a good pointer. Would this need a 2S or 3S battery do you think?
Thank you.
Tim
