DH Flyer Posted August 29, 2012 Share Posted August 29, 2012 Are simple entry level radios dangerous to use with models larger than park-flyers? I am new to the hobby and I learnt to fly on an electric Tomboy. I was recommended to use 2.4 Ghz Planet T5 Transmitter. It works very well but now one year on I would like to fly slightly larger and faster models. In the manual it states that the Tx is recommended for use with Park Flyer and small helicopters. Would it therefore be unsuitable for a Ripmax Coyote or 48" wingspan semi-aerobatic? I would be grateful for any advice Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted August 29, 2012 Share Posted August 29, 2012 Hi, and welcome to the forum. It's not the size of the model as such that tends to be the problem - it's an issue of range. Tx/Rx combinations designed for use with park flyers tend to have reduced range compared to other systems. The issue is of course, as the models get bigger/faster they tend to need significantly more airspace and start being further away a lot of the time - its then that you may run into range problems. I'm not familar with the particular Planet system you refer to, but if it describes itself as a "parkflyer system" I would suggest its not really suitable for the type of larger/faster model you have in mind because of these range issues. BEB Quote Link to comment Share on other sites More sharing options...
NigelH Posted August 29, 2012 Share Posted August 29, 2012 Hi Welcome to the forum. I don't know the TX but there's advice here that suggests that 100m is all you can rely on. That's not very far and you also mentioned going faster so maybe this isn't going to be up to it. Edited By NigelH on 29/08/2012 23:05:38 Quote Link to comment Share on other sites More sharing options...
TheFlyingCrust Posted August 30, 2012 Share Posted August 30, 2012 Found this manual for the Planet T5 transmitter and it's very clear its NOT a full range set. Ian Quote Link to comment Share on other sites More sharing options...
DH Flyer Posted August 30, 2012 Author Share Posted August 30, 2012 Many thanks BEB, NigelH and Rentman I won't risk anything now. I think I'll stick to small and slow models for the while. I build from plans and take a long time so I would hate to see 6 months of sanding disappear due to inadequate radio range. I'll be happy to stick to little vintage models now . . . Thanks for your help. Quote Link to comment Share on other sites More sharing options...
