Danny Wilde Posted January 13, 2008 Share Posted January 13, 2008 I am building the werewolf, it is my first build and its going well, the wings are nearly done and the tail and fuselage too but i need help.I want to use one servo in the fuselage for both ailerons as I only have 4 servos but I am not sure how to do it as the plans sugest that there is a servo for each aileron?? If that is true then how do they work? as the sticks on the tx only control 4 of the channels. Also i am not sure how to do the covering of the plane so any advice would be greatly appreciated.CheersDanny Quote Link to comment Share on other sites More sharing options...
winchweight Posted January 13, 2008 Share Posted January 13, 2008 The two ailerons can either be linked with a Y lead and go into the same channel, or if your tx and rx can do it, they can be assigned a channel each and then used as flapperons etc. I suggest you keep it simple and use two servos and a Y lead. You can buy an additional servo for as little as £5 these days. I will do this build some time, so show us yours, post a few pics and talk us through it. Quote Link to comment Share on other sites More sharing options...
Danny Wilde Posted January 13, 2008 Author Share Posted January 13, 2008 Thanks for the reply. I'll put some pics on once I find my camera, lost the damn thing! Can you get a long enough y lead to span through the wings?Also do you have any advice on the covering??Thanks again and ill look for my camera now to show you. Quote Link to comment Share on other sites More sharing options...
Danny Wilde Posted January 13, 2008 Author Share Posted January 13, 2008 Ah HAAA! Found the camera so here goes with some pics,[IMG]http://img245.imageshack.us/img245/6973/dscn0728hg9.th.jpg[/IMG][/URL][/p][p]hope this has come out ok.[/p][p]As i said this is my first build but so far i found it pretty straight forward , but I am used to reading more technical draqings so that may help. It seems a very sturdy model and would recomend giving it a go. If you want to know anything then just ask.[/p Quote Link to comment Share on other sites More sharing options...
Danny Wilde Posted January 13, 2008 Author Share Posted January 13, 2008 That didnt work then!!I'll try again.<img src="http://img245.imageshack.us/img245/6973/dscn0728hg9.jpg"/> Quote Link to comment Share on other sites More sharing options...
Danny Wilde Posted January 13, 2008 Author Share Posted January 13, 2008 can someone please tell me how to post pics on here?? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted January 13, 2008 Share Posted January 13, 2008 Lee Morgans tutorial.... [img]/forum/smilies/smile_smiley.gif[/img] Quote Link to comment Share on other sites More sharing options...
winchweight Posted January 13, 2008 Share Posted January 13, 2008 For your covering there's always Solafilm or Pro film. A simple to use iron on covering. Quote Link to comment Share on other sites More sharing options...
Former Member Posted January 13, 2008 Share Posted January 13, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
robert graham Posted January 15, 2008 Share Posted January 15, 2008 Danny,Hi, I'm building the DeAgostini Spitfire, I've just finished the covering which is Solarfilm, I think you'll find Pro film is too narrow; you'll need an iron and a heat gun, or borrow your wifes, or sisters hair drier to stretch the material once its been fixed with the iron.The aileron on my spitfire is a single unit and operates both ailerons via a control rod to each aileron operating rod.Hope this helps, Bob. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 16, 2008 Share Posted January 16, 2008 Hi Danny.Use the Solarfilm matt colours as suggested in the text. Hair driers don't give enough heat as far as I can tell. I find that the Solarfilm Supershrink Polyester is the best covering materail of all. I have yet to burn a hole through that, more than can be said for all the others.You did not follow the wing building instructions. You are supposed to fit the 1/8" sheet leading edge to the ribs before sheeting the top of the wing, then there is a second 1/8" strip goes along the front after the wing is complete. This makes a 1/4" thck L.E. With a rebate. Also, fitting tha first strip and then the webs and the sheet make a rigid "D" box before unpinning the wing so preventing any warps creeping in.I see that you are going the 2 servo route. I normally use one servo with a pushrod out to each wing and then a bellcrank and pushrod to the aileron. You can see this set up on my other plans. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 16, 2008 Share Posted January 16, 2008 The easiest way to put pictures on this site is to put them in the gallery, that is easy, any other way is too complicated to bother with. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted January 16, 2008 Share Posted January 16, 2008 No it isnt, it may be bit more fiddly, but hardly complicated once you have a hosting site setup. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 16, 2008 Share Posted January 16, 2008 Why go through yet another website and process when you can do it in one on the Gallery? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted January 16, 2008 Share Posted January 16, 2008 I agree Peter, and this subject has been mentioned many times in various other threads, however, I find the gallery awkward to use, navigation to different albums is complicated, finding just the image you want is fiddly, and worst of all...... any images posted have to to be approved before published.This, to me is crazy because when I am discussing an item in a thread, I want to be able to show /see it immediately, within the thread itself. Using the imagehosting method allows INSTANT insertion of any image, without "approval" ......so why not just sort it so that gallery images also get posted immediately too, AND allow us to post direct from our hard drive to both threads AND gallery ?? Quote Link to comment Share on other sites More sharing options...
kdc Posted January 26, 2008 Share Posted January 26, 2008 We have got away from the original question.The decision on aileron servo location has to be made an early stage. If 2 servos are used , holes for servo lead and plug need to be cut in wing ribs (preferably in alignment so a paper tube can be inserted to guide lead.) and this is best done before wing is started.If one central servo is used then holes for the piano wire pushrods need to be in perfect alignment and this really means they are cut whilst the ribs are still in a pack. Note that holes in balsa are best cut with a sharpened brass tube rather than drilled with a twist drill.I presume Peter Miller is referring to his method of soldering both pushrods into a brass tube together with a piece of threaded rod which is bent twice to bring it up higher to fix into servo arm. Perhaps Peter could post his diagram which makes this clear. ( those of us who have his other plans could scan a copy to do this but its Peters copyright! ) If the wing is already built and holes for pushrod or leads have not been cut , then its messy but still possible to hack holes in the ribs with a Dremel tool or similar using a pointed bit to cut sideways. A jig could be used to locate the holes properly. Piano wire pushrods usually need to be inserted before wing halves are joined. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 26, 2008 Share Posted January 26, 2008 KDC I tried to put a copy of the diagram on one of my albums but it wouldn't accept a TIFF file. Feel free to scan it and post it here to help out. I will see if I can get it on to an album as well Quote Link to comment Share on other sites More sharing options...
Zachattack#9 Posted February 29, 2008 Share Posted February 29, 2008 i am also about to start building the werewolf and would like to know how difficult it is to build (first time builder) Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 29, 2008 Share Posted February 29, 2008 There are easier models to build but if you follow the instructions carefully you should have no trouble.Any problems, just ask and I will try to answer ASAP. Quote Link to comment Share on other sites More sharing options...
Grahame Posted February 29, 2008 Share Posted February 29, 2008 Hi guysI can post a copy of Peter's pushrod diagram (brass tubes/threaded rod) tomorrow for you, hope it helps! CheersGrahame Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 1, 2008 Share Posted March 1, 2008 I have managed to add a drawing of the aileron control system in the Werewolf additonal construction drawings Album in the gallery.http://www.modelflying.co.uk/gallery/images.asp?sp=&v=5&UAbN=393I hope that this helps. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 1, 2008 Share Posted March 1, 2008 PS, IT will have to cleared before you can see it. Hopefully by sometime Monday. Quote Link to comment Share on other sites More sharing options...
Zachattack#9 Posted March 1, 2008 Share Posted March 1, 2008 wat would an easier model be Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 1, 2008 Share Posted March 1, 2008 Well, one with a parallel chord wing might be a bit easier but I can't think of any of my own designs at that size which would be much easier.As I say, just follow the sequence in the instructions and you shouldn't have any problems. If you, just ask. Quote Link to comment Share on other sites More sharing options...
Grahame Posted March 2, 2008 Share Posted March 2, 2008 [IMG]http://img98.imageshack.us/img98/2614/15114882cg4.th.jpg[/IMG][/URL Quote Link to comment Share on other sites More sharing options...
