Peter Miller Posted March 2, 2008 Share Posted March 2, 2008 I posted a diagram on the Gallery and have ben told that it has gone live but it doesn't seem to be there. yet. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 2, 2008 Share Posted March 2, 2008 IT is there but not where I thought it would be. This is my diagram and includes one of the two bellcrankshttp://www.modelflying.co.uk/gallery/image.asp?uin=2163 Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted March 2, 2008 Share Posted March 2, 2008 All photos are cleared Peter. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 2, 2008 Share Posted March 2, 2008 Ah, I see. I thought it was in the extra construction pictures, not my orginal gallery. Quote Link to comment Share on other sites More sharing options...
Stuart Sims ! Posted March 2, 2008 Share Posted March 2, 2008 HI I built the werewolf and found it very easy to build but I could not stand the fusalage being square so I built a proper round won (not very difficult either) as for one or two servo's its so much easer with two plus you can do great things with a computer radio like flaps and thingsjust thought i would add my tuppence worthStuart Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 2, 2008 Share Posted March 2, 2008 Hi Stuart. Glad that you liked Werewolf. How about putting your modified one on the gallery.I don't think many people build from a plan without making some change.What ever you do. Do NOT use the outboard ailerons as flaps or you will get tip stalling. Full span ailerons can be used that way but not out at the tip only. Quote Link to comment Share on other sites More sharing options...
Stuart Sims ! Posted March 11, 2008 Share Posted March 11, 2008 HI sorrey your right silley me tip stall is my down fall. did I say how well it flies brillently ! its powerd by Thyphoon 3630 on 3x3,700 cells turning 13x8 prop Stew Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 11, 2008 Share Posted March 11, 2008 Hi Stuart, Glad to hear that you ar so pleased with Werewolf.. Interesting that you have used electric power. The desing is light enough and has enough wing area for that power.Peter Quote Link to comment Share on other sites More sharing options...
Andrew Bright Posted July 2, 2008 Share Posted July 2, 2008 Hi Peter Am busy with the construction of the Werewolf. No mention is made of angle of incidence of main wing to stabiliser (only the C of G position). Seems from the plans to be about zero degrees, and as I have cut the wing saddle, this is what it has come in as. What did you set it up as?Am busy with making mine electric, so have had to make a few mods to take the battery. Hope to be finished with thhe construction soon, and can then start covering.Andrew Quote Link to comment Share on other sites More sharing options...
