wing tip help on flying wing
Do you mean wing tips or wing tip fins?
If wing tips, there should be no difference than normal construction which would depend on the size and mass of the aeroplane.
If tip fins, I prefer these to be 'knock off' - so they can be quickly and easily glued back into position in the event of an 'incident'. I use thick soft balsa cap ribs and hard balsa/ply laminated fins so the thick rib always gives before the fin breaks
Martyn
