Tony Bennett Posted January 30, 2013 Author Share Posted January 30, 2013 finaly got the wing to bolt on, ailerons and final fitting out and we are done. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 30, 2013 Author Share Posted January 30, 2013 Well i had some lunch and got back to work. made up the mounting blocks for the nose and screwed that on. then because my bits i ordered yesterday had turned up, i got on with getting the elevators to work. then i found some wheels. so i got the ailerons left to do, seal the wing and fit the motor and esc. then it is done and i can have a go at something else. at the moment it weighs 3lb 10 oz and needs 1lb 3oz to get the c of g right. motor, battery and esc should see to most of that. Quote Link to comment Share on other sites More sharing options...
Martyn K Posted January 30, 2013 Share Posted January 30, 2013 Hi Tony If that comes in at under 5lbs then that is very light. Very impressed. Martyn Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 30, 2013 Author Share Posted January 30, 2013 i do build light. won't be under 5lb though. 4s battery, motor, esc come to aboult 2lb, so it will be just under 6lb all in. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted January 31, 2013 Share Posted January 31, 2013 6lb is still pretty good going for a 60 size model Tony. How much power will it have? Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 31, 2013 Author Share Posted January 31, 2013 it is having an electric motor producing 875 watts on a 4s battery with a 12x6 prop. so should have some power spare. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted January 31, 2013 Share Posted January 31, 2013 875W - around the same power or a little more than a later Merco/K&B/Fox 60, that should do the job nicely. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 31, 2013 Author Share Posted January 31, 2013 hope so. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 1, 2013 Author Share Posted February 1, 2013 right well the ailerons are on, painted and working. just got to seal the wing and buy the motor/ esc and jobs done. so i went back to the mustang for a while. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 2, 2013 Author Share Posted February 2, 2013 wing is now sealed and once dry i can bolt it all together for some pics. need to order a motor now and it is finished. YAY. whats next then. Quote Link to comment Share on other sites More sharing options...
Concorde Speedbird Posted February 2, 2013 Share Posted February 2, 2013 Posted by Tony Bennett on 02/02/2013 19:54:09: whats next then. You know what I want next... CS Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 2, 2013 Author Share Posted February 2, 2013 waiting on plans csb. Quote Link to comment Share on other sites More sharing options...
Martyn K Posted February 2, 2013 Share Posted February 2, 2013 I just want to see this fly... M Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 3, 2013 Author Share Posted February 3, 2013 just waiting for the motor and esc and it is all finished and ready to go. bye bye aeroplane. hello next project. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted June 10, 2013 Author Share Posted June 10, 2013 well time for an update. new owner finally got round to flying it, here is his report. "the Pattern ship Tony built for me. Does it shift, it like a bullet, very very fast. Had half a flight with it, until the motor shed the prop,spinner, and nuts and washers in the long grass about 200 yds away. The motor screamed up then stopped,as it had burned itself out ??? ESC is fine. When the prop went , I thought now we will see what the glide is like, absolutly perfect, managed to line it up and drop it in to a perfect landing" Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted June 11, 2013 Author Share Posted June 11, 2013 As stated earlier, the maiden was only a 2 min flight due to the motor shedding the prop, so yesterday I remotored the model, and substituted a 35/48 for the supplied 35/36 supplied motor. So today was the second maiden I guess. It was blowing poss 15 mph when I arrived at the airfield. a fact I was pleased about as the model glides rather fast. Model took off and as it was trimmed on the first maiden, I started to see how it performed. Rolls on low rates were very axial and when I changed to high rates, the only difference was they were faster. Loops are as big as you want, stall turns are a dream, and it seems to do anything I want it to do, except the spin, but maybe that was down to me . After a flight of 7 1/2 mins I lined it up for a landing, throttled down and she came in perfectly to about 3 ft from the ground, a tough of up elevator and 2 clicks of power was all that was needed to put her down on the rear wheels, and as the ground speed bled off the nose wheel came down for a perfect landing. The model needed 6 oz of lead to get the C of G right, which doesnt supprise me as it is a verry short nose. Does it fly well?, YES IT DOES!!!! I had another 4 flights with it, and all the flights were great, and landings were perfect, Its a great model Quote Link to comment Share on other sites More sharing options...
