Joe Foster's Mark 8
T.B. you can avoid the bleed under the tape by applying a coat of the base colour over the edges , it works for me ,I also prefer to use the 6mm tape from Flair or Tamya as it follows curves quite well , if the curves are tight I use the 3mm tape BTW great colour schemeyessmiley
p.s and get that wing made for that Lancer ! wink
got the fuselage sealed, well 2 coats of sealer. last one will go on after i have fitted it out.
Put the first coat of paint on the underside of the wing.
got the blue on the top of the wing.
need to do the white when dry, then a second coat.
fit the ailerons and seal.
then it is just the job i hate, fitting out and final tidying.
