winchweight Posted February 13, 2008 Share Posted February 13, 2008 In typical male fashion I fitted my ESC in my Air Blaster, flew it, then read the manual for the ESC. It says it can either have a soft or hard start. But what does that mean? Why is there a difference? Which should I have on an Outrunner with 3S Lipo power?Also should I utilise the prop brake function, or just let it idle when on approach? Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted February 13, 2008 Share Posted February 13, 2008 Isn't it complicated ? I know what you mean Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 13, 2008 Share Posted February 13, 2008 Probably wont make a lot of difference, but soft start is normal, with hard start being used for certain large outrunners which sometiomes "kick" a bit when first starting up from stopped.Now before you ask you might want to learn about the other 2 common setting available on many ESCs TIMING. Outrunners prefer Hard / High timing (20-30 degrees) Most ESC's work fine with midrange timing on outrunners If you find that the ESC loses sync (squeals) when the throttle is advanced rapidly,…. then increase the timing to hard or even very hard. Harder timing also increases rpm and current draw, but it reduces efficiency Inrunners prefer Soft / Lower (2-5 degrees). You can use harder timing for more power from Inrunners if you want to, with higher amp consumption, - Hacker suggest up to 5 degrees for normal use. <!--[if !supportLineBreakNewLine]--> PWM ( pulse width .....or frequency ) Outrunners prefer lower PWM (8kHz) Inrunners typically prefer higher PWM (up to 32kHz).There, now you know Quote Link to comment Share on other sites More sharing options...
winchweight Posted February 14, 2008 Author Share Posted February 14, 2008 And the brake function? On or off, or does it matter? Quote Link to comment Share on other sites More sharing options...
YakMad Posted February 14, 2008 Share Posted February 14, 2008 Unless it's a powered glider I leave the brake off as the free wheeling prop acts like a brake to slow your landing speed, just remember free wheeling equals no thrust so don't be fooled into thinking the motor is still pulling the model when in fact it's not, no brake seems to allow the motor to deliver power faster if needed as there is no start-up as the motor is already spinning. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 14, 2008 Share Posted February 14, 2008 Yakmad is spot on. Quote Link to comment Share on other sites More sharing options...
Former Member Posted February 14, 2008 Share Posted February 14, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
winchweight Posted February 15, 2008 Author Share Posted February 15, 2008 Lovely thanks. i look forward to a bit of leccy flying this weekend.Sorry about the delayed response I have been to that there London to see Stomp, Tutankhamun and The Eye. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 15, 2008 Share Posted February 15, 2008 And which was your fav bit ? Quote Link to comment Share on other sites More sharing options...
winchweight Posted February 15, 2008 Author Share Posted February 15, 2008 Stomp deffo. I saw them about 6 years ago in New York, and had to take the missus to see it. Birmingham was sold out, so London it was. Absolutely fantastic show. loud, but brill. Tutankhamun was fascinating, but we went to Luxor on holiday and cruised the Nile visiting the sights along the way, so it would never be as good. And the Eye is an egg on a wheel. Given my job it was a bit dull. The weather wasn't great so the view was a bit limited. Stomp is highly recommended. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 15, 2008 Share Posted February 15, 2008 Mmm must try and get some tickets then Quote Link to comment Share on other sites More sharing options...
winchweight Posted February 16, 2008 Author Share Posted February 16, 2008 Wish i'd known. I had three but in the end only two of us went so I gave away one ticket for each venue! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 16, 2008 Share Posted February 16, 2008 Doh!It sounds a good show, we love the whole musical west end broadway type thing, and have seen most of the big shows, here and a couple in New York too. Been on the eye a couple of times ( different guests with us on each occasion ) and we are in London for a few days every few months or so, as my stepchildren both live in the city. Quote Link to comment Share on other sites More sharing options...
