ericrw Posted September 17, 2013 Share Posted September 17, 2013 Today, on connecting my transmitter to my Beaver model my Turnigy Plush 60 amp ESC is making an intermittent beeping sound and the motor is having a jerky movement. The elev, rud, ail all responded when I switched on but no joy from the throttle. It worked fine the last time I flew but today a problem. Is the ESC faulty or do they go to sleep ?? Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted September 17, 2013 Share Posted September 17, 2013 Dry jointt between motor and esc? That seems quite a common problem Quote Link to comment Share on other sites More sharing options...
ericrw Posted September 17, 2013 Author Share Posted September 17, 2013 Sorry ! I've just realised that I had problems previously with this ESC and was able to resolve the problem through the Forum. Quote Link to comment Share on other sites More sharing options...
Pete B Posted September 17, 2013 Share Posted September 17, 2013 Try some 'down' trim on the throttle, Eric. IIRC, I've had similar in the dim and distant past and I can't remember if that fixed a similar problem..... Next option would be to 'teach' the ESC the throttle position and see if that helps. If not, I'll have a harder think - I'm rushing past the Pc at the mo.... Pete Quote Link to comment Share on other sites More sharing options...
ericrw Posted September 17, 2013 Author Share Posted September 17, 2013 The previous Forum help, again proved to be the answer. As to why it happened again ( going to sleep). I don't know ! Thanks again to the forumites !! Quote Link to comment Share on other sites More sharing options...
Pete B Posted September 17, 2013 Share Posted September 17, 2013 I'm none the wiser, Eric - how did you wake it up? Do you have a link to the previous thread? Pete Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted September 17, 2013 Share Posted September 17, 2013 The trick is to avoid giving them any Horlicks before putting them away Eric......then they stay wide awake until you need them again.... But from the symptoms you describe I think I'd line up behind the learned Mr Cotsford.....a dodgy joint between ESC & motor would be my guess.....a badly soldered connector is often the culprit!! Quote Link to comment Share on other sites More sharing options...
Pete B Posted September 17, 2013 Share Posted September 17, 2013 I think I've found the thread, Eric. Was it the trim? Useful for other forumites to remember Pete Quote Link to comment Share on other sites More sharing options...
ericrw Posted September 18, 2013 Author Share Posted September 18, 2013 Pete, yes I had had this problem before but in a "senior" moment I forgot that I had. It was the trim. I had to put the trim to it's lowest level and then connect to the battery. How is the Grandson keeping ? Quote Link to comment Share on other sites More sharing options...
Pete B Posted September 18, 2013 Share Posted September 18, 2013 Very well, thanks, Eric - learning lots of bad habits from his elder brother. I'll be seeing them next week Pete Quote Link to comment Share on other sites More sharing options...
