Frog Mustfire
Thanks, the wing is quite a complex build but it is immensely strong. The supplied sheet is a harder grade than I would have chosen for a plan build, but I want to see how it comes out using the supplied materials (U/C blocks excepted). At most it will be a few oz heavier than it could have been, but there's plenty of area to cope with it.
Jeff, did you swap some fin area for rudder? What is the finish, film or paint? I'm going with film, I know it was available in the late '60s as I covered a combat wing with orange Solarfilm in '67 or thereabouts, only to discover it didn't like diesel fuel.
  • 1 month later...
Nearly two months gone by already?
OK, Christmas done and dusted, decorating done - for now - so time to catch up.
The wing sheeting is finished and tip blocks fitted, the ailerons completed including drilling for 3/16" hinge points, servo mountings fitted for Corona wing servos, hatch surrounds fitted, wing bolt plate and dowel location added to the fuselage so:
Servo mounts - liteply support, birch ply hard point pads for the screwsservo mount .jpg
You know you are getting somewhere when you start tapeing elevators and ailerons on:
Looks fantastic Bob , a real model plane made from chunks of wood and lovingly carved to shape ,much better looking than the modern day cnc jigsaws devilwink
I will say that if it was my model, I would be thinking about spending a few more quid on some profilm , the HK stuff is o.k. and I have used it several times but it's just not as good ? imho but that's just me being picky dont know anyway ,looking foward to seeing the end result !
Jeff, I think I've used all the films at one time or another and really can't tell a lot of difference between them if you exclude the original thin easy-melt Solarfilm. The only exceptions were some fluorescents I got from GC/GS, which were heavy and reluctant to follow compound curves. I'll give this a go on the curvy bits first and see how it comes out.
One interesting point that showed up when mating the wing and fuselage was that the seat didn't match the wing section by a good 3/16" at max camber. I checked the fuselage against the plan - spot on, ditto for the wing section. In fact both were die-cut in any case. Just goes to show inaccurate plans and cutting are nothing new!
Bob ,sorry should have made myself clearer , I was referring to the fact that there is a issue with the colours fading ,the transparent ones being the worst ,think the white should be o.k. though ! laugh
And yes ,I remember the often miss-match between wing/wing seat teeth some of those old kits left a lot to the skill of the builder to make good.
A bit of a heads up for those that like these older designs. Just got off the phone with ' Belair' and I was told that they intend to market a parts set for the Frog Mustfire in the next 2-3 months. Hope I've not been speaking out of turn but, for those that may be interested, it may pay to keep an eye on their site over the next few months.
Thanks, let's not forget all the hours of entertainment (?) in actually building it. What does a trip to the cinema cost - £7 a throw last time I went for 2 or 3 hours entertainment. I reckon this comes into triple figure hours for around £80. Less than a weekend ticket to Donnington Park.
I knew the fuselage felt light, that's what prompted me to sling it on the kitchen scales (kitchen scales? they may live in the kitchen but there's never been any foodstuffs near them), but the wings felt much heavier so it was a surprise to see them come out within an oz of each other.
It just shows though what can be done with traditional building methods and good design. I was always impressed by Mick Reeves' ability to combine light weight and strength, typically in the 63"Spitfire and Fw190. Foam wings obviously have some limitations, although I've always been happy with what I've had, but looking at my just acquired MR Fw190D-9, (another one)! the fuselage with foam cored tail feathers attached and 52" long, weighs 23ozs. I'm very interested in some of the wonderful results we are seeing now with Depron and glassfibre, might have a go at it, but it's hard to beat what you see in the Mustfire and Mick's 190.
Good one Bob.
AUW 6 lb 15.5 oz which is more than I'd expected, but thinking back I hadn't allowed for the tank or undercarriage. The box lid quotes 6 1/2 - 9lb, so I guess it should be ok. With no added lead it balances about 1/4" back from the plan position so that's not bad though it could do with an oz in the left wingtip.
I think I need to get Tim on the case with some stickers to break up the large areas, do you think the old style of having my BMFA number on one wing would be over the top? A 'Mustfire' on the top of the left wing is a definite, it would be nice to get a Frog trademark sticker too.
  • 3 weeks later...
So for the first flying session of 2014 I took three models to the field:
Dragon Lady - nice reliable old girl to get my fingers back in the mood
PushyCat - maiden due
Mustfire - Maiden due
So after the range checks, failsafe checks, little-bits-of-fuel-tube-on-the-clevises check I fuelled up the DL, switched on the ignition and faithful as ever it fires straight up.
And dies after 10 seconds. No compression - take off the rocker cover and a nut drops out, with half the tappet adjuster in it. No DL today then.
Ok, PC time. Connect the battery, demonstrate the Taranis safety switch custom function to Eric, and break the toggle off the hatch catch. Bu99er.
What can go wrong with the Mustfire? I'm ready for anything now. Answer - nothing, the Evo 10GX fires up sweet as a sweet thing, a touch of right rudder to keep her straight and away she goes. Not overpowered by any means but a nice steady flyer. It needed a few clicks of left trim (I forgot I still need to add lead to the left wingtip) and that was it. The stall is definitive when it finally happens, sharp nose down with no preliminary mushing, but it comes at a silly low speed. Stall turns from straight and level show the lack of power, there's no time to tart it up with any rolls, speed bleeds off rapidly. 4 flights later I'm a very happy bunny.
So what does it need - a bit of lead in the nose might make it less sensitive to elevator on landing, some weight in the left wingtip to balance it up and that'll do me. A nice side effect of using the petrol motor is that after a 10 minute+ landing flight the 8oz tank was still over half full!
Edited By Bob Cotsford on 09/03/2014 18:57:30
