A Collins Posted March 26, 2008 Share Posted March 26, 2008 Hi, I'm just building my very first plane from plans and have a bit of a sticky problem. My local hobby shop recommended cling film to protect the plans and stop they cyno sticking the plane to the plan. It didn't work as I expected and I ended up with a rudder nicely covered on one side with cling film. What do others use to prevent their models sticking to the plans? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 26, 2008 Share Posted March 26, 2008 Many still swear by rubbing a candle over the plan. Also, take a photocopy, and use the copy to work from, preserving the original. Finally, why not try some thin acetate sheet like they used on o/head projectors and so on. One guy I know uses X ray film Quote Link to comment Share on other sites More sharing options...
A Collins Posted March 26, 2008 Author Share Posted March 26, 2008 Thanks Timbo...now where did we put the candles? Quote Link to comment Share on other sites More sharing options...
Fats Flyer Posted March 26, 2008 Share Posted March 26, 2008 the thin plastic sheet cover protectors for decorators in diy stores is excellent,i use it all the time ...lasts for ages Quote Link to comment Share on other sites More sharing options...
Alistair Taylor Posted March 27, 2008 Share Posted March 27, 2008 I use the plastic sheeting that's often used to cover selection boxes of chocolates - Lindt chocolates in particular.This seems to be impervious to cyano, but consuming sufficient chocolates to keep a steady supply of sheeting has resulted in significant weight gain....AlistairT Quote Link to comment Share on other sites More sharing options...
A Collins Posted March 27, 2008 Author Share Posted March 27, 2008 Thanks everyone, the chocolate wrapping has my wife's vote Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 27, 2008 Share Posted March 27, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
HughG Posted May 17, 2008 Share Posted May 17, 2008 This is a bit late in this topic, but I agree with Eric on the use of backing sheet - very useful and effective. I'd sound a note of caution over the use of photocopying. Unless you have access to a very good copier, it's more than likely that the copy will not be accurate in length and/or width. I've found this out the hard way with more than one photocopier. Make sure you check carefully!Hugh Quote Link to comment Share on other sites More sharing options...
Rick Tee Posted May 17, 2008 Share Posted May 17, 2008 Hmm building with cyano shudder! Cling film works for me, but i don't build with cyano. Quote Link to comment Share on other sites More sharing options...
260 Flyer Posted May 17, 2008 Share Posted May 17, 2008 I use industrial cling film, the stuff that is used to wrap pallets. The film is thicker and has so much plasticiser in it that it feels greasy to touch. Although it is not my preferred adhesive, when i have used cyano it has come away from the film OK.You can get the wrapping film from Staples or other industrial outlets. Quote Link to comment Share on other sites More sharing options...
Dennis Ainsworth Posted May 17, 2008 Share Posted May 17, 2008 Hi all, just bought my first tubes of UHU por glue for use with Depron, never used it before and all the writing on the boxes and tubes is in German.Can anyone please assist as to how to use it, is it like Evostick etc. Glueing two wing sheets together do you have to cover all the surfaces or just in spots dotted about. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 17, 2008 Share Posted May 17, 2008 Coat each surface with a thin film, then leave for at least 5 minutes , bring together and voila. Its basically a contact adhesive. Quote Link to comment Share on other sites More sharing options...
Dennis Ainsworth Posted May 17, 2008 Share Posted May 17, 2008 Thanks Timbo much appreciated. Quote Link to comment Share on other sites More sharing options...
Dennis Ainsworth Posted May 18, 2008 Share Posted May 18, 2008 By the way as regards protective film while modelling, Solarfilm used to sell building film as well. Quote Link to comment Share on other sites More sharing options...
HughG Posted May 18, 2008 Share Posted May 18, 2008 Can't see it on their website. I'm going to check out the wrapping film mentioned by Rob. Quote Link to comment Share on other sites More sharing options...
