scott finnie Posted February 20, 2014 Share Posted February 20, 2014 I was working away with my twinstar bench testing with it's new 3 blade yellow (safety) prop's in place when there was a bang and one blade flew off and into my foot, i had thin sandals on that i wear in the garage and it went through them leaving a nasty hole in my foot! Luckily not too much damage more cosmetic but could have been worse, time to re consider what i wear in the garage as i wear safety goggles all the time and gloves, just never thought my feet would get hit by a awol blade, luckily it's almost stopped bleeding, time for a beer and bed, oh and never to buy cheap props again! I'll stick to master airscrew.... Quote Link to comment Share on other sites More sharing options...
Wiltshire Flyer Posted February 20, 2014 Share Posted February 20, 2014 Ow mate! Never mind cheap props, should have been A&E! Quote Link to comment Share on other sites More sharing options...
scott finnie Posted February 20, 2014 Author Share Posted February 20, 2014 Posted by Wiltshire Flyer on 20/02/2014 03:56:09: Ow mate! Never mind cheap props, should have been A&E! Yes i know i'm going to pop along to the doctor in the morning and see what he say's . I have cleaned it out with un diluted TCP and now bandaged it up, it was the second bad thing to happen today after pilot error brought down my raptor 50 heli into a weed infested pond, should have just went to bed instead of staying u tinkering Quote Link to comment Share on other sites More sharing options...
MikeS Posted February 20, 2014 Share Posted February 20, 2014 Scott, that looks bad. Though could have been a lot worse I imagine. We all buy cheaper versions of things time to time but these props need to be banned if they can go that easy. Mike Quote Link to comment Share on other sites More sharing options...
Old Geezer Posted February 20, 2014 Share Posted February 20, 2014 Sorry to hear of your accident Scott, just a word of advice though: TCP undiluted might very well kill any bacteria driven into your foot by the errant prop' blade, but it would probably be just as effective at the recommended dilution. Undiluted antiseptics/disinfectants can cause chemical damage (necrosis) to the tissues exposed by the cut, and some are actually more effective at standard dilution than in their concentrated form. P.S. Hope the foot's feeling better now and you didn't get too much "Boys and their Toys" grief/ribbing either from SWMBO or down at the Medical Centre! Quote Link to comment Share on other sites More sharing options...
scott finnie Posted February 20, 2014 Author Share Posted February 20, 2014 Hi all, i have contacted the seller on Ebay and awaiting hopefully a quick reply, i had bought 4 of these props and the other 2 are being used with an airboat, under examination there is white fatigue cracks where the blade joins the hub on all of them, the one's being tested last night where only at 75% of power it looks as if the blade has stretched before letting go in such a catastrophic manner, i will give the seller 24 hours then file a complaint to Ebay, cant have blades flying around , they are designed for high kv motors aswell, well thats what there advertised for, off to the doctors at 1030, now that its daylight it does look messy but clean, will keep you updated, Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted February 20, 2014 Share Posted February 20, 2014 While it could very well be a manufacturing fault, there's also the possibility of damage during transit or assembly with any propeller so Scott's foot should serve as a reminder to inspect props for damage before first use and on a regular basis. Quote Link to comment Share on other sites More sharing options...
