Steve Houghton Posted June 25, 2015 Share Posted June 25, 2015 Yes, it's coming together again very nicely Pete. I'm always amazed at how quickly many models can be repaired. It's just a matter of getting over that first hump of despair at where to start! There's certainly no way that switch was ever going to be poked by the 'launch hand', even if it were to match Phil's great photo! Perhaps you'll change your mind about avoiding wires now - I think they are a great idea. Love the shoes - bet they're great for recovering wayward models from the Mermaid pool without getting wet feet! Quote Link to comment Share on other sites More sharing options...
Peter Garsden Posted October 12, 2015 Author Share Posted October 12, 2015 So at the Orme this weekend, I couldn't understand on my 4th flight with the JP why it wouldn't roll. It was flying with only one aileron but I didn't realise at the time. Decided to land and misguidedly applied the air brakes - both ailerons up and some down elevator - with one aileron it went into a spiral dive but forunately landed on a down slope, but still cracked the wing and broke the wing dowel. This is the damage I found when I took the covering off. Good job I stripped it as it was pretty badly cracked. Should have cut a new piece of 1.5mm sheet rather than trying to piece it together - anyway too late now, so will see. I think I am going to cover the wing with some 25gram fibreglass cloth and water based varnish to give it extra strength. Quote Link to comment Share on other sites More sharing options...
Andy Meade Posted October 13, 2015 Share Posted October 13, 2015 A shame about the damage Pete, but glad the repairs are underway already - good stuff Quote Link to comment Share on other sites More sharing options...
Peter Garsden Posted May 23, 2016 Author Share Posted May 23, 2016 Yet another JP crash at the Bwlch - this one was a puzzle. I was pulling round at quite some speed for a landing. I pulled on the switch which usually operates the spoilerons (both ailerons up and elevator slightly down) when it went into an uncontrollable dive and broke the same wing which broke last time. I was really annoyed as it happened in full view of everyone. I have repaired the wing now. I think it was weak from the last repair which was just a glue back together job. This time I inserted a 1/16" ply brace into the wing next to the spar, which should be a lot stronger. I am also going to cover with some 25gram cloth top and bottom. So how did it happen? I fired everything up on the bench and pulled the switch - both ailerons went up but the elevator went down about 8mm - far too much and enough to provoke a vertical dive - the reason was that I was using my new transmitter for the first time, which was wrongly programmed! I also realised that I had also programmed in Butterfly which was activated using the throttle stick, so I was probably engaging that during the flight.How annoying Quote Link to comment Share on other sites More sharing options...
Peter Garsden Posted May 26, 2016 Author Share Posted May 26, 2016 I have now covered the damage in silver solarfilm, but had to cut off the lettering from underneath. I just couldn't find the right font for the lettering so I could print it off on clear decal film and stick it on. I searched for RAF Lettering Font and found this site - has all the Air Force Lettering Fonts you might ever need - now installed on my PC - **LINK** I have now printed the N and the 5 onto the film and sprayed it with clear lacquer to make the ink jet printing waterproof. Quote Link to comment Share on other sites More sharing options...
Andy Meade Posted May 26, 2016 Share Posted May 26, 2016 I didn't see it go in this time Pete. Poor old girl will be mostly glue now! Edited By Andy Meade on 26/05/2016 16:04:06 Quote Link to comment Share on other sites More sharing options...
Peter Garsden Posted May 31, 2019 Author Share Posted May 31, 2019 I am thinking of making a double size Jet Provost. I hope Andy will oblige by letting me have file which I can take to the printers. Quote Link to comment Share on other sites More sharing options...
Andy Meade Posted June 3, 2019 Share Posted June 3, 2019 Double check with Simon Cocker and John Hey - they have two complete double sized kits in their possession. I think they are veneered foam, so maybe they can get another cut, or sell-on their bits? Quote Link to comment Share on other sites More sharing options...
Peter Garsden Posted June 6, 2019 Author Share Posted June 6, 2019 Ah thanks Andy. Will do. Quote Link to comment Share on other sites More sharing options...
