Olly P Posted April 22, 2014 Share Posted April 22, 2014 I have to say this ability to set up the model on the PC and then share the setup for assitance is one of the key things which makes me look at the Taranis and contemplate tring it out...... Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted April 22, 2014 Share Posted April 22, 2014 We have some good feedback on OpenTx with suggestions and very helpful video!. See here to follow what's happening over there. BEB Edited By Biggles' Elder Brother - Moderator on 22/04/2014 13:01:04 Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted April 22, 2014 Share Posted April 22, 2014 Thinking aloud So what would happen if a spare channel was set up with the delay as a single line for not SB up and the various flap settings created as mixes of this dummy channel? PS the videos work from a tablet! Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted April 23, 2014 Share Posted April 23, 2014 I've found another way of doing this - with guaranteed no bounce and any timed settings you want! The clue came from Mike on OpenTx - when he said you can only have one "slow statement" on any one channel. So, what I've done: 1. set up a curve (say curve 1) that is y=0 at x=-100 and y=45 at x=+100 (45 is the percent of your max flaps - whatever that is) 2. program the flaperons in the mixer screen - with SB as an input (yes you can have a general switch without a position indicator as a channel input!) So now the mixer looks like this: CH01 (+100%)Rud CH02 (+100%)Ele CH03 (+100%)Thr CH04 (+100%)Ail (R Ail) (+100%)SB Curve(Curve 1) Slow(u1.3:d1.9) CH05 (-100%)Ail (L Ail) (+100%)SB Curve(Curve 1) Slow(u1.3:d1.9) And so you only have one "slow statement" per channel. I've simulated this in C9X and it works fine - no bounce. And it has the virtue of being shorter - ie fewer lines of programming! JVR - I'll email you the binary file and you can try it out. You will just need to copy and paste the lines into your model if you want to use it - don't forget to set up the curve - you will find that in the bin file as well under the "curves" tab. BEB PS Obviously you could still add your elevator compensation off SB as you had it originally with this programming, that will be the same. Edited By Biggles' Elder Brother - Moderator on 23/04/2014 17:11:37 Quote Link to comment Share on other sites More sharing options...
J V R Posted April 24, 2014 Author Share Posted April 24, 2014 BEB Yes that works nicely, just tested on the plane & I have put Ele compersation on SA to have a bit more control if its not needed or the % need's altering jvr......... PS you have e-mail Edited By J V R on 24/04/2014 13:59:56 Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted April 24, 2014 Share Posted April 24, 2014 Glad that works! BEB Quote Link to comment Share on other sites More sharing options...
