Chris Parsons Posted April 28, 2008 Share Posted April 28, 2008 HI all. First time in forum but would be interested in your views on the JP Prangster. Have just bought one and am half way through building it. Seems a bit wierd - building a plane out of EPP and corrugated plastic covered in parcel tape. Does it really fly well? Bought an Enya 40ss to go in it. Had a Wot Trainer prior with an SC40 but my tutor kindly introduced it to the field rather faster than it would have liked!! Destroyed the front end, ripped the undercarrage and wings off, bend the wing joiner and am minus ailerons as well. Doh! Cheers for your comments in advance. Quote Link to comment Share on other sites More sharing options...
Andy Sayle Posted April 28, 2008 Share Posted April 28, 2008 I used to fly a Prangster, and I loved it! It taught me that IC planes are not for me, but was bloody good fun in the process Mine was setup with an SC46, which was just about right power wise. Enough for almost vertical flight, but not prop hanging. My main flying site was the local beach, and it was surprisingly resilient, although there are one or two weaknesses.The spar (wooden square section stuff) was easily broken, and the undercarriage wire was far too spindly, and if glued in, impossible to replace. On mine I replaced it with a straight bit of carbon tube, that was a tight push fit in the wing cutout (Meaning it can be replaced easily!). It meant that there was no dihedral, but that made aerobatics a bit easier which was nice. Most of my landings in the beginning resulted in the legs splaying out, and stopping the engine because the prop hit the ground (and that was the case even after I got quite good at landing too!). Also, you have to be really careful not to warp the tail feathers. If you store the plane in a hot car, or a hot workshop, make doubly sure nothing is being distorted by something resting on a surface for example.The only thing I didn't get on with, was the fact all the servos were buried in the fuselage, and it was a major surgery job to change a gearset, or adjust a snake or similar.As for flying, then so long as everything is straight, then it was very nice to fly. It was almost impossible to stall (just dropped a nose, and went all mushy), and generally great fun to hoon around with! I only sold it in the end to switch to Electric stuff (I couldn't be doing with all the gunk and cleaning!)...CheersAndy Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 28, 2008 Share Posted April 28, 2008 I echo everything Andy has said, my wife was learning on one last year, but has now moved up to the WOT4.My somewhat tired Prangster is currenty looking for a good home - perhaps you would like it for spares ? ( a freebie ) Quote Link to comment Share on other sites More sharing options...
Chris Parsons Posted April 29, 2008 Author Share Posted April 29, 2008 Thanks for the offer Timbo. I'm in the Bristol area. What would your postage costs be? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 29, 2008 Share Posted April 29, 2008 I have no idea, but I could guess at around 10 -15 quid ? Quote Link to comment Share on other sites More sharing options...
Chris Parsons Posted April 29, 2008 Author Share Posted April 29, 2008 That'd be fine. Do you want to email me and I'll let you have my address details. Do you use paypal? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 29, 2008 Share Posted April 29, 2008 Hi Chris. I will try and find a suitable packaging to send it in. It is a little ropey now, but there may be some bits you could useI will send some photos of the bits with an email before you commit PS please fill in your profile page and then you can add the "message me" button to your pages, and posts, without actually revealing your email address ( better for spammers )Yes I have PayPal...but only if your PayPal account is actually funded, otherwise they charge me to receive money. Quote Link to comment Share on other sites More sharing options...
Alan B Posted April 29, 2008 Share Posted April 29, 2008 Hi ChrisI again agree with what Andy says. They will take a lot of abuse and they fly well. Once you have covered it in that supplied tape to strenghen it. You can then cover it with that sticky back plastic you can get in the cheapy shops for a couple of quid. Just make sure though it is fuel proof! . As far as the under carriage is concerned, I have put a large cable tie across mine at the top to stop it compressing on landing. I have also fitted a small tail wheel to give it more control on the ground.Al Quote Link to comment Share on other sites More sharing options...
Andy Sayle Posted April 29, 2008 Share Posted April 29, 2008 Oh, that's the other thing, Alan B has just reminded me. The ground handling is awful when there is a bit of wind.... Still, you don't buy a plane for its ground handling right? CheersAndy Quote Link to comment Share on other sites More sharing options...
Captain Slow Posted April 30, 2008 Share Posted April 30, 2008 I learnt on a prangster and still have it. The original GP42 was adequate - the 46LA made it a hooligan!I keep threatening to get rid of the dihedral and change the throws to see if I can make it more like the 3D version without having to spend out It's fairly robust - make sure the engine is mounted using nuts and bolts (mine came with self tappers!). I've only managed to snap the dowel and cowl on mine (or course it was a glitch *cough* pilot error *cough*).Don't take the pee with it and you won't break it. Fly it like a balsa plane and you will be able to land (on grass) comfortably with the engine running. If you can do that on an unmodified u/c you're landings will really improve - you can consistantly touch and go with this plane (3" wheels).Enjoy Quote Link to comment Share on other sites More sharing options...
James Beard Posted July 10, 2008 Share Posted July 10, 2008 I am flying a Prangster right now. It was my first glow fuel aircraft, after messing about with aerobirds...Runs like a dream on my OS 40 LA. I have had some pretty bad crashes in my early stages of learning to fly, my worst accident ripped off the exhaust from the engine (which is a problem having it inverted on this model.. some people advise to have the engine normal way up but I have not bothered since my flying has improved loads from constantly flying this Prangster.)I have had to replace the wing brace once as well... the whole brace inside had bent on one side and I am still not sure how this happened (someone thinks it was an extreme g-force situation .. hehehe ) again, recommendation is to replace the wing brace with a carbon fibre rod, but I dont think its neccesary as its a trainer really....I changed the wheels to larger ones as well as I am taking off from bumpy farmland in the Forest Of Dean.Landings are a dream, you can almost float down. I have almost finished my first low winger now (BH Super Air) and am 100% confident of flying this, all thanks to the JP Prangster.. I cannot recommend this model enough as a first IC aircraft. Then its onto the H9 Spitfire ........ Quote Link to comment Share on other sites More sharing options...
Roy Wellington Posted January 31, 2009 Share Posted January 31, 2009 Hello Prangsters!! Has anyone out there ever converted a Prangster to Electric? If so, what set up did you use. I would be most grateful for any and all information. Thanks Quote Link to comment Share on other sites More sharing options...
flytilbroke Posted January 31, 2009 Share Posted January 31, 2009 Major surgery required I think, as well as additional bracing to replace the removed foam, that leccy stuff needs a cooling airflow. Even if the control unit is positioned outside the fuselage the battery pack still needs cooling. A .40/.46 equivalent motor needed, Puffin models or BRC might have a suggestion or two. I think better to use an leccy type trainer. Quote Link to comment Share on other sites More sharing options...
Roy Wellington Posted January 31, 2009 Share Posted January 31, 2009 Hi Flytilbroke -(I'm alread there!!!) Thank you for your reply. Certainly from what you say it would appear that there are far too many changes to be made to the Prangster and a ready made/designed leccy is the best option. Thanks anyway Quote Link to comment Share on other sites More sharing options...
