iqon Posted July 30, 2014 Share Posted July 30, 2014 I am trying to fit a Turnigy G110 to my own design , although i am using the cowl from a Phoenix models Accipiter. The problem i have is that the cross mount does not give me the clearance i need for the slope of the cowl. First Question does anybody know if the G P mount can be modified to a shorter adjustable length I am after around 60mm, GP do a adjustable length that i need but it says for small motors, wound it be upto the job of the G110. Lastly and maybe more importantly if i have not got the clearance for the cross mount am i subject to overheating. would I be better off moving the motor down 1" or so and making my own cowl.... Thanks Quote Link to comment Share on other sites More sharing options...
Attilio Rausse Posted July 30, 2014 Share Posted July 30, 2014 Mount the motor the other way round ie xmount nearest the firewall, you then bolt the prop driver to the motor case. Til Quote Link to comment Share on other sites More sharing options...
Attilio Rausse Posted July 30, 2014 Share Posted July 30, 2014 I use 18~22 mm dowel cut to length ie 60mm drill down centre (drill from both sides) then socket head bolts (80mm) into captive nuts in firewall. Til Quote Link to comment Share on other sites More sharing options...
Attilio Rausse Posted July 30, 2014 Share Posted July 30, 2014 I would avoid using the motor mount because 1. its much heavier than the method described above. 2. the type of prop driver (one that grips the motor shaft) used is prone to slipping and if bent (noseover) will mean motor strip down to fit a new shaft. Til Quote Link to comment Share on other sites More sharing options...
iqon Posted July 30, 2014 Author Share Posted July 30, 2014 Have spent all day fitting motor using standoffs, using standoffs meant that the motor had to be fitted lower due to slope on the cowl, The GP mount would have meant that it would be in the correct position but would have been too close to cowl for cool running, i`m happy with the compromise... Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted July 30, 2014 Share Posted July 30, 2014 And you've saved a few grams (and pounds) in the process Quote Link to comment Share on other sites More sharing options...
