.. Posted August 7, 2014 Share Posted August 7, 2014 Hi chaps, I'm looking for a bit of help/info on this airframe. Looking through the internet I think this is a 63 inch wingspan Brisol Blenhiem can anyone confirm if it's from a balsa craft kit or were there other kits available ? It was built by my father Inlaws father some years ago but never flown. It's been stored in an attic for a good few years & I now have taken position. The only build flaw I can see is an off centre horizontal stab so that will need sorting. It looks to be powered by two in runners and we did manage to get her running this afternoon but unfortunately the elderly speed controller let its smoke out. So the project is to get her in the air and give her a go so any info is much appreciated. Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted August 7, 2014 Share Posted August 7, 2014 The Balsacraft Blenheim is 60" span, powered by two sp600 motors, in the original kit configuration . Built up sheeted fuselage and wings, with flat plate sheet balsa tail surfaces. Does the Blenheim look like this at all? That's a Balsacraft Blenheim. Edited By leccyflyer on 07/08/2014 20:25:31 Quote Link to comment Share on other sites More sharing options...
kevin b Posted August 7, 2014 Share Posted August 7, 2014 Any photos Justin ? Quote Link to comment Share on other sites More sharing options...
.. Posted August 7, 2014 Author Share Posted August 7, 2014 Yes I've managed to get one into my album but can't get it on the forum at the moment? Quote Link to comment Share on other sites More sharing options...
Depron Daz Posted August 7, 2014 Share Posted August 7, 2014 Here's my Blenheim. I used the plans from the BC kit but sourced my own balsa. I also extended the nose to make it resemble the MkV Defo change the inrunners for B/L and use lipos rather than the heavy nicads, but you will need to add weight to the nose as there is a big difference using lipos and B/L motors. Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted August 7, 2014 Share Posted August 7, 2014 Nice Blenheim Budgie Daz -is that a fixed U/C or retracts? Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted August 7, 2014 Share Posted August 7, 2014 Justin The model in your pictures looks like a Flair Beaufighter, rather than a Blenheim. \ Quote Link to comment Share on other sites More sharing options...
Depron Daz Posted August 7, 2014 Share Posted August 7, 2014 Yep, that looks like a Beaufighter. Believe it was a BC kit also. Leccyfliyer, they are electric retracts. The nacelles are made from balsa and depron, and the "humps" are made from blue foam. The whole nose is on dowel pins and rare earth magnets, and the lipo slides in a snug fit tray. Balances perfectly. The fully individually glazed cockpit was a bit of a nightmare but looks good. Edited By Budgie Daz on 07/08/2014 21:50:27 Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted August 7, 2014 Share Posted August 7, 2014 Very nice too. The nose on my Blenheim is removable also - secured with 4mm gold bullet connectors. FwiW Balsacraft never made a Beaufighter - that's definiitely a Flair Beaufighter - the too slender cowls are a dead giveaway. Edited By leccyflyer on 07/08/2014 22:03:06 Quote Link to comment Share on other sites More sharing options...
Depron Daz Posted August 7, 2014 Share Posted August 7, 2014 The uneducated are now wiser. Cheers Leccy. I know a few guys at my field that use the bullet connectors also, good tip. Quote Link to comment Share on other sites More sharing options...
.. Posted August 8, 2014 Author Share Posted August 8, 2014 Ahh exelent service chaps , many thanks. So has anyone got any info on C of G etc and also the flying charictoristics ? My Father in Law is going to look for the original plan . As I stated the horizontal stabiliser is well off square so I would like to see the assembly to ascertain where is best to cut to make it true. Posted by leccyflyer on 07/08/2014 21:40:01: Justin The model in your pictures looks like a Flair Beaufighter, rather than a Blenheim. \ Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted August 8, 2014 Share Posted August 8, 2014 Justin I have the instruction booklet and accompanying stuff from the Flair Beaufighter kit and can give you any of the required information when i get in from work this evening. Alternatively, Flair do tend to put most of the vital information up on their website. **LINK** Quote Link to comment Share on other sites More sharing options...
.. Posted August 8, 2014 Author Share Posted August 8, 2014 Yes many thanks again, a quick google search bought that up, and also it looks that it was 3 channel to the lack of a moveable rudder isn't an error. I am looking forward to flying this one. Quote Link to comment Share on other sites More sharing options...
A.A. Barry Posted January 17, 2016 Share Posted January 17, 2016 Any help with a plan or a Blenhiem??? thanks Barry Quote Link to comment Share on other sites More sharing options...
David Davis Posted March 17, 2016 Share Posted March 17, 2016 Posted by A.A. Barry on 17/01/2016 15:17:34: Any help with a plan or a Blenhiem??? thanks Barry I have been given a Balsacraft Blenheim kit to build by another club member. I haven't even opened the box yet so I don't know what sort of plan was provided with the kit but if it's a conventional sort of plan, I'll get it copied for you if you'll pm me your address. We plan to fit brushless motors and a LIpo. Any suggestions for this modification greatly received by this unreconstructed i/c enthusiast! Quote Link to comment Share on other sites More sharing options...
