Garry Pollard Posted May 1, 2008 Share Posted May 1, 2008 As a long time modeller, I have returned after a long layoff. I decided to go electric and have a query. With an ARF model it appears that no on off switch is provided Should I wish to insert one where would it go in the wiring? Any help would be great. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 1, 2008 Share Posted May 1, 2008 DONT. The only secure way to ensure both positive connection AND disconnection is to simply unplug the battery.Best practice is to remove the battery for charging anyway. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted May 2, 2008 Share Posted May 2, 2008 What model do you have Gary? Quote Link to comment Share on other sites More sharing options...
Former Member Posted May 2, 2008 Share Posted May 2, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Garry Pollard Posted May 2, 2008 Author Share Posted May 2, 2008 Thanks Timbo thought I may be complicating things a bit also thanks Eric Cessna 182 David Ashby Quote Link to comment Share on other sites More sharing options...
Helidel Posted May 2, 2008 Share Posted May 2, 2008 Many ESCs have a switch which only isolated the receiver, this is OK to use until you get back to your pit area, (it stops the prop turning,) then disconnect the battery. Even with this sw off the motor will drain current from the battery until disconnected. Quote Link to comment Share on other sites More sharing options...
Garry Pollard Posted May 2, 2008 Author Share Posted May 2, 2008 Thanks Helidel I am new to electric flying and have a lot to learn Quote Link to comment Share on other sites More sharing options...
Helidel Posted May 2, 2008 Share Posted May 2, 2008 OK Garry,Keep your eyes on this forum, "electrymystyfying" is the way to go Quote Link to comment Share on other sites More sharing options...
