4 stroke Throttle Linkage
I've just seen what looks like an excellent piece of kit from DuBro stocked by SMC and could make running throttle linkages a whole lot easier! The pushrod from the servo is connected to a lever fixed at one end to the engine bearer and a short linkage transfers the movement of the lever to the throttle arm. Very simple and very effective. I copied a picture of it from the DuBro site but I'm not sure if copyright would permit me to post it here.
Hi Doug
Just to help you out on this one. It applies to anything specific you want to link to. Basically what you do is put your mouse cursor over the article. Left click - then click on properties - a box will appear including the link -   http  etc. - highlight the link and then left click again and then click on copy. Then go to your document  ie: here then position it where you want it to appear- then left click again and click on paste - the link should then appear as below.
http://www.dubro.com/catalog/images/hobby_cat_2007_1-28%20copy.jpg
or
Or once copied click on the link symbol above and paste it in the URL box.  Type in the Title box something like  "click Here "  and insert
Click Here
Well it normally does in this case it gives you the jpg
Al
