Dave Bran Posted November 20, 2014 Share Posted November 20, 2014 Two models recently set up have the Aileron trim reversed! (The surface works correctly and so does the trim when opposed to normal) Anyone save me time on what might be the cause please? Quote Link to comment Share on other sites More sharing options...
PatMc Posted November 20, 2014 Share Posted November 20, 2014 Dave, have you reversed them in the "Input" page ? Try the "Servo" (preferable but both servos) or the "Mixer" page. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted November 20, 2014 Share Posted November 20, 2014 Check to see if you have "include trim" ticked in the aileron mix. I had a funny like this on an elevon model recently. If you have to reverse one of the two aileron channels in the mix then include trim (but don't take the reverse into account) weird things happen! BEB Quote Link to comment Share on other sites More sharing options...
J V R Posted November 20, 2014 Share Posted November 20, 2014 I've a similar problem setting the timers up on a new model, the run time only stops at full throttle, but I can not see what's been done or what I have done to make this happen. Any ideas ?? Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted November 20, 2014 Share Posted November 20, 2014 What are your exact timer settings in the model Setup screen JVR? Quote Link to comment Share on other sites More sharing options...
J V R Posted November 20, 2014 Share Posted November 20, 2014 Hi Chris, I will pop out to the shed later today and have a look at the TX settings Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted November 20, 2014 Share Posted November 20, 2014 Another question JVR - have you reversed the throttle? If so where did you put the reversing in? BEB Quote Link to comment Share on other sites More sharing options...
PatMc Posted November 20, 2014 Share Posted November 20, 2014 JVR, is it an ic model with the throttle reversed in the "Input" page with the servo channel number selected as "Throttle Source" in the "Setup" page ? Edited By PatMc on 20/11/2014 14:44:08 Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted November 20, 2014 Share Posted November 20, 2014 JVR I've just reproduced your issue by setting up the Timer as a THs so it works off the throttle, AND I've ticked Reverse Throttle in the Model Setup page. This causes the timer to run all the time EXCEPT when the throttle stick is at the top of travel. If what you want, is for the timer to only be stopped at the bottom of Throttle travel, untick the Reverse Throttle option, then go to the servos page and reverse the throttle servo. Quote Link to comment Share on other sites More sharing options...
J V R Posted November 20, 2014 Share Posted November 20, 2014 Thanks Lads I have just sorted this one with your help ( Chris, Beb & Pacmc ) I would have answered early but I had to attend our Anniversary meal !!! Bless her she's had to put up with me for 22yrs of Military vehicle shows & now RC planes as well. Jan.......... Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted November 20, 2014 Share Posted November 20, 2014 Congrats JVR Quote Link to comment Share on other sites More sharing options...
