Gavin Livsey Posted May 9, 2015 Share Posted May 9, 2015 Replacing my written off Global Sbach with a Hobbyking Edge which was in the recent sale at a price too good to miss. I could use my DLE 30 but would like to try an electric set up. I've trawled through the various forums but most suggest motors and esc's not available this side of the pond. Anyone done a conversion using reasonably sensible priced parts? I' d like to limit the lipos to 8S (2x4S) but haven't ruled out 10S. Estimated weight is about 12lbs. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted May 9, 2015 Share Posted May 9, 2015 I'm running this with an 8s (2 x 4s) 5,000 mah lipos and a 75A ESC and a 18 x 12 prop, on a fresh battery it pulls 75 amps at WOT, about 1800 watts or about 2.4 hp, the motor and batteries would take a larger prop, but we'd need to up the ESC. This combo is in our Ampley electric tug (6kg) and it will take that vertical and has no problems towing a 4m glider. Our ESC is a castle creations one, because that's what we had. If you are buying new, then go for a 100 amp esc and make sure it can handle high cell counts (the cheaper ones stop at 4 or 6s) Quote Link to comment Share on other sites More sharing options...
ben goodfellow 1 Posted May 9, 2015 Share Posted May 9, 2015 not long since i sold my 140 e... had an axi 5330/18 / 90 amp esc . was about 2750 watts . more than 30 cc power on 10 s Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted May 9, 2015 Share Posted May 9, 2015 My Carl Goldberg Sukhoi SU26 weighs in at 11lb 15oz and flew on 12S with a Hyperion ZS-4045/12 motor, HobbyWing Platinum 120HV ESC, and 16x10 APC E prop giving 2540 watts. I replaced the motor with a Hacker A60-L/16 and an 18x10 prop, giving 1910 watts, because the Hyperion motor's shaft bent too easily. I chose 12S because I have 6S packs for my helis. My amps are only 40-45, so you could easily generate similar watts using 10S and more amps, provided the model can take a larger prop. Quote Link to comment Share on other sites More sharing options...
Attilio Rausse Posted May 9, 2015 Share Posted May 9, 2015 This motor http://www.hobbyking.com/hobbyking/store/__38053__Turnigy_Aerodrive_SK3_6364_213kv_Brushless_Outrunner_Motor_UK_Warehouse_.html and this ESC http://www.hobbyking.com/hobbyking/store/__29665__Turnigy_dlux_80A_HV_Brushless_Speed_Controller_OPTO_UK_Warehouse_.html Use either 10 or 12S 12S for lower current draw (for same KW) but higher RPM Weight and size will be a deciding factor for which batteries to use. All my battery packs are 4 and 6S (3000mah) this gives me 6, 8, 10, 12S combinations. Would be very surprised if 8S would give the required power as a 30cc engine would. Quote Link to comment Share on other sites More sharing options...
Gavin Livsey Posted May 10, 2015 Author Share Posted May 10, 2015 Thanks chaps. Quote Link to comment Share on other sites More sharing options...
