Simon Hall 2 Posted July 3, 2015 Share Posted July 3, 2015 I have noticed on my oldest of 2 Radians that there was some play when you pull on the prop assembly. I only noticed as the prop assembly has become a bit noisy compared to the other plane. The newer Radian does not have any play. I took off the spinner cone and undid the prop nut. It's just the adapter in the pic that has play, but the shaft is static. I have a new prop adapter and was going to try fitting it. I removed the small grub screw with the tiny allan key head, but the adapter does not come off. Any ideas as to what the problem could be here, apart from me! Thanks. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted July 3, 2015 Share Posted July 3, 2015 Maybe thread-lock has crept between the adapter and shaft? I wouldn't advise a heat gun on the adapter for obvious reasons but can you heat a large lump of metal and use it to heat the adapter? I'm sure you've looked on the opposite side for a second grub screw! Quote Link to comment Share on other sites More sharing options...
Simon Hall 2 Posted July 3, 2015 Author Share Posted July 3, 2015 Hi Martin, yes there is no opposite grub screw. I was pulling quite hard by hand and it did not budge. Could it have somehow grooved the shaft and lodged itself in there? There seems to be something else in there on the shaft. I tried pressing it gently with a screwdriver thinking it could be a sort of release bearing or something. I can't really make out how it attaches to the shaft as it's so tiny. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted July 3, 2015 Share Posted July 3, 2015 I'm thinking thread-lock due to the pink colour around the threaded hole... Quote Link to comment Share on other sites More sharing options...
Simon Hall 2 Posted July 3, 2015 Author Share Posted July 3, 2015 Any idea why there would be play on the adapter? Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted July 3, 2015 Share Posted July 3, 2015 My first thought would be an unbalanced prop/spinner has caused it to wear on the shaft. John Edited By john stones 1 on 03/07/2015 17:56:56 Quote Link to comment Share on other sites More sharing options...
Simon Hall 2 Posted July 3, 2015 Author Share Posted July 3, 2015 So the best way to remove the adapter would be heat instead of brute force? If the shaft is worn, does that mean a new motor? I don't know anything about prop balancing, the props are standard and all I do is wipe any crud off them after flying. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted July 3, 2015 Share Posted July 3, 2015 I would think the adaptor is most likely worn it's softer material, and you can buy replacement shafts anyway for a motor Simon...but i'm only guessing on the causes John try giving it a squirt of release oil before you apply any heat you never know your luck Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted July 3, 2015 Share Posted July 3, 2015 You could try rigging a ersatz puller, by using a socket spanner head that fits fully over the adaptor but rides in the motor, then use a spinner nut (the type with a tommy bar hole) with some piano wire through the hole so that as you tighten the spinner nut the piano wire engages with the socket and as you tighten the spinner nut the pressure it transfered onto the motor face and with luck and a following wind it should come off Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted July 3, 2015 Share Posted July 3, 2015 If you can get some long nose pliers on the shaft Simon, try fitting a prop to the adaptor and rock it back and forth, you might break loose whatever is holding it ? John Quote Link to comment Share on other sites More sharing options...
Simon Hall 2 Posted July 3, 2015 Author Share Posted July 3, 2015 Thanks John, I will give it a try. This seems like the easiest option for me to start. I will try to put some padding on the pliers teeth as I don't want to damage the shaft. Quote Link to comment Share on other sites More sharing options...
