Fiberglass sheet for servo horns
I need to make some custom control horns for an unusual tail setup.
2mm fiberglass sheet would be ideal but the minimum order I can find is about £10. A lot of money for two servo horns
Anyone know of any low cost source of 2mm sheet or know of a good alternative
Maplin sell PCB which might suit your requirements although I don't know the thickness.
Alternately any scrap computer, washing machine  or TV etc might produce a bit of circuit board that would give enough material for a few horns - check your loft or the local recyclying centre.
Edited By kc on 26/07/2015 12:15:34
