Phil 9 Posted August 29, 2015 Share Posted August 29, 2015 I need some solid tube that 2mm push rod will fit through with little slop. I think an internal diameter of 2.5mm would be ideal it is to make a bolt on tail so light weight would be advantage I have found some carbon fibre tube online but the postage seems to be astronomical Can anyone suggest anything that cost less than £20 for some short (10cm) lengths of solid tubing Quote Link to comment Share on other sites More sharing options...
simon barr Posted August 29, 2015 Share Posted August 29, 2015 Depending on the loads that are expected on it, would a Biro pen inner do...? Or some snake inner...? Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted August 29, 2015 Author Share Posted August 29, 2015 biro pen may be a bit wide snake tune may work though Quote Link to comment Share on other sites More sharing options...
Foxfan Posted August 29, 2015 Share Posted August 29, 2015 Aluminium tube from K&S metal centre? MrTin Quote Link to comment Share on other sites More sharing options...
Attilio Rausse Posted August 29, 2015 Share Posted August 29, 2015 http://www.ebay.co.uk/itm/Brass-Tubes-2mm-7mm-300mm-long-0-45mm-wall/360513204144?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D33052%26meid%3De3754622b13046ee99197399a26119a2%26pid%3D100005%26rk%3D4%26rkt%3D6%26mehot%3Dpp%26sd%3D321839626677 copy the link and paste into browser address bar. try maccmodels on ebay, I have used his services loads of times you need 3mm brass tube (wall thickness 0.45mm. Til Edited By Attilio Rausse on 29/08/2015 10:13:44 Quote Link to comment Share on other sites More sharing options...
onetenor Posted August 30, 2015 Share Posted August 30, 2015 Dural is a bit lighter but veeerry strong Same dia needed Quote Link to comment Share on other sites More sharing options...
onetenor Posted August 30, 2015 Share Posted August 30, 2015 should have saidtry Rice International phone 01872 572 200 Quote Link to comment Share on other sites More sharing options...
cymaz Posted August 30, 2015 Share Posted August 30, 2015 Try THESE people.... Quote Link to comment Share on other sites More sharing options...
