Ian101 Posted January 24, 2016 Share Posted January 24, 2016 It's funny you should have started this now as I also started another one over Christmas. I seem to remember you started your first one at the same time I started mine! This one is the same size, but just a display model for somebody so should be quick and straightforwards. In the same time I have roughed out a nose, you are nearly finished. Quote Link to comment Share on other sites More sharing options...
Martian Posted January 24, 2016 Share Posted January 24, 2016 wonderful build blog Ian Quote Link to comment Share on other sites More sharing options...
Electriflier Posted January 24, 2016 Author Share Posted January 24, 2016 Posted by Ian101 on 24/01/2016 10:43:19: This one is the same size, but just a display model for somebody so should be quick and straightforwards...... I've heard that one somewhere before Colin, I understand that to be true after hearing it at a visit to see the old lady (Vulcan) at Finningley a couple of years ago. I'd be highly surprised and probably a little concerned if this one reaches anything near 76 MPH!! Anyhow, Sunday is usually the day for flying or, if the weather is not up to much, visiting family. The family again won through as, once again, the weather has been . Before setting off, I managed to wire-up the landing lights for their first test. What's more, took a little bit of video. Forgive the less than perfect filming and post production but I was in a hurry. Cheers Roy thinking about it, it might have been a good idea to switch them on Edited By Electriflier on 24/01/2016 21:05:00 Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted January 24, 2016 Share Posted January 24, 2016 Blimey! That's clever. Quote Link to comment Share on other sites More sharing options...
Philip Rawlinson Posted January 24, 2016 Share Posted January 24, 2016 Brilliant they are on the right side of the wing and facing down ????? Quote Link to comment Share on other sites More sharing options...
Electriflier Posted January 27, 2016 Author Share Posted January 27, 2016 Not a great deal to report apart from the latest mvideo of the working landing lights coupled with the retracts. It's been ..... interesting, shall we say, setting up the micro switch and routing the wiring. I've decided that the lighting circuit connections from the wings to the fuselage will be mini jacks into chassis-mounted mini jack sockets which will be presented on the fuselage root rib. Not as mission critical as servos or retracts so I made connecting them up easier than standard servo lead connections. I'll post some photos once I have tidied up the installation. I had wires all over the place when I took this video this evening but the object of the exercise was simply to ensure my wiring was correct and all worked fine which I'm pleased to say.....did! The model, precariously balanced on the foam model stand (stood on edge ) so to allow for the lights and retracts to drop without being impeded. See what you think. Gotta say, I think they look the doggie's ........! Regards Roy Quote Link to comment Share on other sites More sharing options...
Pilot_Chuckle Posted January 27, 2016 Share Posted January 27, 2016 Wow Roy,looking good. Lights look very bright ! Brave to balance the model on the stand, I know how flimsy it can be. Look forward to seeing it on Saturday. Quote Link to comment Share on other sites More sharing options...
Philip Rawlinson Posted January 27, 2016 Share Posted January 27, 2016 Macgyver he say wow Quote Link to comment Share on other sites More sharing options...
Electriflier Posted February 4, 2016 Author Share Posted February 4, 2016 Aileron and Elevator servos have now been installed into the wings. Blue foam, lightply and the trusty old servo mounts used yet again. (Hey, if it ain't broke.....) I've used Metal-geared 17gm servos for the aileronsw and full sized servos for the elevators. It is my intention on this build to configure the model as 'Elevon' rather than, as in the past, simple elevator/aileron. Why? - I just want to see if there's much difference in flight characteristics. The ailerons and elevators were made from 1/8" balsa sheet with 6mm depron ribs. The leading edge was made from 1/4" balsa sheet stripped down to allow for the taper along each control surface. (wider towards the inner wing and tapering toward the wingtip) Being made from 1/4", was thick enough to allow me to cut an angle in each L/E rather than using triangular section which I normally do. The anchor points for the bolt-through control horns was reinforced with 1/16" ply on each side fo the 1/8" balsa sheet before the components were finally skinned in 3mm Depron. Came out pretty neat Cyano-type hinges were slotted in place ready for later. Apologies for the lack of photographs of the building of the control surfaces but my camera/phone was playing up at the time. The wingtips, like the control surface, were not photographed so suffice to say, i carved and sanded some blue foam blocks to shape once they'd been glued to the end of the wing plates. Last job before thinking about skinning the wings was to ensure ALL the servo extension leads were functioning. I NEVER assume the leads to be working, even though straight from the packet as I once installed a faulty aileron lead and skinned the wing only to find it later. Lesson learned.......... Anyhow, all tested out fine, 3mm depron was applied to each wing. I'm not going to go into how to skin a wing with 3mm depron as I've described it many times in past builds. Other than to say, as usual, I used copious amounts of UhU Por. Time for a few photo's now the camera is working Oh yes, forgot to mention, notice, I managed to stick my thumb through the 3mm skin. It was very windy and whilst trying to set this picture up, the wing tried to make a break for it Next update, I'll show you what I did with one of these...... Here's a clue...... For now...... Regards Roy Quote Link to comment Share on other sites More sharing options...
Philip Rawlinson Posted February 5, 2016 Share Posted February 5, 2016 Your builds get better and better Quote Link to comment Share on other sites More sharing options...
Electriflier Posted February 5, 2016 Author Share Posted February 5, 2016 Cheers Phil. I think it's that I've learned to take my time Again, a day of getting those niggling little jobs done. Even more servo wire has been added today in the form of 4 x 1000mm extensions to supply the right and left ailerons & elevators. Notice also in the pic below that I have added a 'pocket' on the outer fuselage ribs to house the aileron/elevator connections once the wings are in place. With all wiring installed, I decided to remove the 'dorsal' fin of the Vulcan to enable easier application of the skin to the curved area at the very top of the fuselage. I've already decided to replace the depron dorsal fin with 1/8" balsa so that I can taper the shape more finely into the fuselage rather than with 6mm Depron skinned each side with 3mm (12mm). With the fin removed, a more straight-forward job then to apply the first skin to the fuselage body. The curved 3mm upper fuselage section can be seen here before I PU'd it into place. Once the 3mm skin had been applied, I reinstalled the dorsal fin, as already described, in 1/8" balsa. Cored-out to minimise weight. I teased you a little yesterday with the inclusion of the picture of the Maplin's blue xenon strobe unit. Ok, breaking away from the strictly scale aspect of the build, I decided that i'd like to see a working strobe running once gear was lowered. Along with the wing landing lights, switched when the gear drops, I've added a cheeky little xenon flash (white) just aft of the front retract. It doesn't exist on the real thing I know but hey, I think it will look great on finals A clear plastic half-sphere will protect the Xenon lamp on belly landings although the lamp itself will be below the level of the 3mm depron skin... For now...... Regards Roy Edited By Electriflier on 05/02/2016 19:38:02 Quote Link to comment Share on other sites More sharing options...
Electriflier Posted February 7, 2016 Author Share Posted February 7, 2016 The weather being the weather yet again today has allowed me to spend some time today preparing the fuselage for skinning. Checking over every interlocking piece of Depron for raised or sunken edges that will have an effect on the overall finish has taken quite a long time. All excess blobs of PU glue have been cut away and sanded again, to ensure there are no 'bumps' in the finish. Before I'm able to commence skinning of the fuselage, I had to complete the remaining air brake unit. Sadly, I've had to 'borrow' two 17g servos from the larger Vulcan so as to match the two on the other air brake, The suppliers are out of this particular servo until next week at the earliest so rather than hanging on until I can get 2 more, 2 donor servos were used. Made identically to the left air brake unit, will slot into place in a compartment in the fuselage. Both air brake modules installed in the fuz..... Although built identically, and as opposites (L&R), If I'm only going to use 1 channel for their operation (and I am), I had to install a servo reversing lead between the right and left pairs of brake servos. The reversing 'Y' lead now ensures correct operation of the air brake units. So, to clarify, each brake has two servos, 'Y' leaded together. Each 'Y' lead is then plugged into the servo reversing 'Y' lead leaving the remaining plug to be plugged into Aux 1 on the receiver. (Clear as mud!) Anyhow, it works! Until I set the servo end points on the airbrake channel, care has to be taken if using the servo tester as it just throws the air brake vanes too far and strains the servos. So, I'll post a video once I have installed the radio gear and am doing testing of each channel. Skinning could now commence. Having built this aircraft twice before, I have decided this time to approach the skinning process a little differently. By this i mean, rather than attempt to follow the intricate compound curves on the belly with panels of depron, I have cut away all curved sections of the fuselage formers so that the whole underside can be skinned almost in one piece. The pieces that I removed will then be re-introduced once the underside is skinned. Here's a picture of that very process Having smoothed off the underside of the fuselage skeletal components, I then was able to lay the fuz flat onto some 3mm Depron and mark around my glue points. I trimmed the sheet to size (plus 1/2" or so) and then set about applying the Uhu Por over the 6mm Depron edges that will make contact with the skin. Once done, rubbed UhU along each marked-off area on the 3mm sheet. By the time I had finished, the adhesive was ready for bonding and so carefully, laid the sheet in place on the underside of the model. Far easier than in past builds trying to work the sheeting around the many complex shapes on the belly. That's about as far as I got today but it's been worth taking this approach as the finish is really nice and smooth. A final picture showing the lower air brakes deployed. Til the next one..... Regards Roy Edited By Electriflier on 07/02/2016 20:14:56 Quote Link to comment Share on other sites More sharing options...
chris Ibbotson Posted February 8, 2016 Share Posted February 8, 2016 Hi Electriflier, This a great build and fascinating to watch and follow. Seems to me this Vulcan is having the same problems as XH558 did, problem of parts availability. Now you have scavenged the servos from the 100" Vulcan, will she be grounded du to lack of certification. I've had a look at my servo stock and found 4 new 17g (same as yours) which you can use if you need, just ask. regards Chris Quote Link to comment Share on other sites More sharing options...
Electriflier Posted February 8, 2016 Author Share Posted February 8, 2016 Chris, Thanks for the kind offer! I'll bear it in mind but I'm pretty sure there'll be no hold-ups with regards to getting the big Vulcan flying again. This afternoon, I have been able to progress a little with the fuselage skinning. This time, i made a start on the topside of the fuselage. The flat sections of fuz that run alongside the central body, I in-filled the compartments with 6mm depron pieces. Not only does this give me something to glue the 3mm skin onto but offers further rigidity and alignment to the edges of the curved central section. This shows the infills alongside the central curved section of the fuselage.. I've found, when working with flat, uncomplicated sections of skinning, that paper templates are definately the way to go. You can make as many mistakes as you want with the paper. Easiest if you pin the paper down to the structure you're covering then running firm pressure along each edge with your finger to indent the shape into the paper. The edges of the root ribs can clearly be seen after running your finger along the edges. It's clear, working this way, that the adjoining edges of the 3mm Depron, where the flat skin meets the curved central section that I'll definately be using some 3mm grey depron neaded into the joints to provide a fairing between both surfaces prior to filling. On past builds, as I've mentioned previously, I've worked the fuselage skinning in many panels to follow the many complex compound curves. This way is far easier so far. The end results? well we'll see soon enough! A few more pictures for anyone who's interested of progress to date. Regards Roy Quote Link to comment Share on other sites More sharing options...
Pilot_Chuckle Posted February 8, 2016 Share Posted February 8, 2016 Looking good, hope the wife was out when you took that picture lent against the wall Quote Link to comment Share on other sites More sharing options...
Philip Rawlinson Posted February 8, 2016 Share Posted February 8, 2016 In the name of sustainability do you replant 20 depron trees for every 20 you chop down This one is looking awesome Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted February 8, 2016 Share Posted February 8, 2016 I like that, Depron trees! Might be an idea to plant a few off those in my back garden. Quote Link to comment Share on other sites More sharing options...
gliggsy Posted February 8, 2016 Share Posted February 8, 2016 looking good and getting closer Roy, keep up the good work....g Quote Link to comment Share on other sites More sharing options...
Electriflier Posted February 11, 2016 Author Share Posted February 11, 2016 Thank you chaps! The evening before last, I rolled some 3mm white Depron onto a brush staff to sit overnight in readiness for the exhaust tubes for the model. The edge of the 3mm Depron was taped to the brush handle before carefully rolling the rest of the sheet tightly around. Once I had managed to roll the whole sheet, I taped the free edge down and sat it on a radiator overnight. The next morning, tape removed, it hardly budged. In fact, it was quite a task to unroll the Depron off the brush handle to get to the tape that was holding it on. The roll relaxed into this permanent state once it had been unrolled and un-taped from the brush handle. The underside of the fuselage is where most of the jet tubes show and again, I thought it best to first, cut a paper template before attempting to cut from Depron sheet. I forget to mention that I had glued slithers of 6mm depron around the edges of where the 3mm tubes would meet the fuselage to give me something to glue to rather than simply glueing to the surface of the fuz. The 6mm slithers of depron and the paper template on the underside of the fuselage. Before I cut the required shape from the 3mm Depron sheet, I cut some 60mm roundels of 6mm Depron to act as formers within the jet tubes. The diameter along the length of the Jet pipes remains constant at 60mm, so all I had to do was reduce the depth of the roundels to give the effect of the jet tubes flowing into the fuselage. The 60mm dia Depron roundels (formers for the jet tubes) decreasing in height the further forward they come. With the 3mm Depron skins applied, starting to look the part A bit of tidying up to do at the back end but looking good so far. Starting to skin the central fuselage rear section with 3mm. It was starting to become obvious to me that I had to think soon about the motor installation as I'm getting very cloe to enclosing the motor mount So, motor bolted on, i'm now able to refer to my drawings and confirm the size of the motor cowl that will be added to the end of the fuselage. I need to get this blue foam cowling sanded down to something close to the required shape before I skin any more of the fus' and, that's as far as I manged to get today. Progress nonetheless, Regards Roy Edit:...... just realised also that I haven't mentioned that I skinned the vertical stab and rudder yesterday. Edited By Electriflier on 11/02/2016 21:31:48 Edited By Electriflier on 11/02/2016 21:33:45 Quote Link to comment Share on other sites More sharing options...
Pilot_Chuckle Posted February 11, 2016 Share Posted February 11, 2016 Oh my g∆? you never seize to amaze. Unbelievable work and methods. Always leaning. Quote Link to comment Share on other sites More sharing options...
Philip Rawlinson Posted February 12, 2016 Share Posted February 12, 2016 Brilliant, I think this is going to be almost as awesome as the Texan and the Mosquito Quote Link to comment Share on other sites More sharing options...
Electriflier Posted February 13, 2016 Author Share Posted February 13, 2016 Lol, always learning....... you're not kidding! Thank you Phil. As some of you will know, today, I definately proved to myself that i am officially 'losing it' I took the model to the shop where it would be far easier for me to assemble it as there is more room and also Charles there to lend a hand. It was when I came to plug everything together, realised that I have skinned the fuselage BEFORE i have fully completed installing the extension cables. So, absolutely gutted and even more, disappointed in myself, I had to fish, force, persuade, gouge, poke sorry, route two more 1m extension cables to supply the main retracts. I cannot believe I let this happen as I have made myself check off each job before progressing onto the next!!!! As I said - Losing It. Anyhow, frustrations aside, i was able to snag the build progress to date. Problems that I have found that need addressing were 3.5mm gold connectors that were pre-installed on the motor required changing to 4mm. Thank you Charles for sorting that one out for me. The left wing front carbon wing locator needs breaking out and re-aligning as the fit against the fuselage could be much better. Loads of sanding, filling, sanding etc over the coming week. Hopefully, address the aforementioned issues then I'll decide whether or not to glass certain parts of the model, notably, the removable nose section.' Anyhow, that's next week. In the meantime, a couple more pictures from today. Cheers liking this picture Quote Link to comment Share on other sites More sharing options...
Electriflier Posted February 14, 2016 Author Share Posted February 14, 2016 Like I said, filling, sanding etc etc. Looking better though as the imperfections are smoothed out. Had to take this opportunity to start sanding as the weather has been really good today. It allowed me to work outside which was a MUST as the dust would have made a right old mess indoors. Wasn't able to spend all day on the build today as jobs around the house were calling. Once I had caught up on the chores, spent an hour messing around heat-forming some fairings that I'll be using on the rear of the model to keep the motor cool. I had previously carved and sanded these balsa shapes for another build and never used them. Shame to let them go to waste so I glued one to each side of a piece of block balsa thus: Then I cut the top off a small bottle of tonic water and pushed the balsa block inside and tehn applied heat from a heat gun. Almost instant results as the plastic bottle shrinks around the balsa plugs. Hardest part of the job was cutting them free from the bottle once it had cooled down. A little bit more trimming, a coat of paint and they'll do fine. Cheers Roy Quote Link to comment Share on other sites More sharing options...
Electriflier Posted February 20, 2016 Author Share Posted February 20, 2016 Its been a week since I last updated the log so I thought I'd better catch up. Wife asked me last week what I wanted for my Birthday present which is during Feb. This is what I asked for..... .6 oz glass cloth and a bottle of EzeKote for my birthday. - well chuffed! I'd been pondering whether or not I'd cover the model and as I'm in no rush to get this one finished thought - 'why not?' For the small amount of additional weight, decided to invest the time in going for a good finish ( with additional strength) Before I could start though, I still had one or two jobs to finish on the fuselage. The rear ECM pod needed completing (around the ESC and the parachute bulge etc) so I cracked-on getting these done. In an attempt to get as much cooling as possible around both the motor and the ESC, I have decided to base the aircraft on XM655 which is still painted in the split colour scheme (camo' on top - white underside) and also allows me to cover the ESC with a dummy heat exchanger on the rear of the model. OK, the heat exchanger is slightly over-sized but I'd rather have a cool ESC than risk overheating. The ESC can be seen on the side of the model prior to adding the heat exchanger cover. I've cut a hole in the top-side of the tail to facilitate additional cooling to the motor which will be disguised as the parachute bulge. I have also built-in another air scoop on the underside towards the rear,just ahead of the motror which I'll point out later (once I have taken a photo). Reasonably happy that I could commence glassing, I prepared the fuselage by painting on a thinned coat of Eze-Kote. I started on the fuselage top as you can see here:- The top was covered in 3 pieces of .6 oz glass cloth and put aside overnight to dry. Next, I made a start on the wings. To cut a long story short, the whole of the topside of the model took me around 3 hours to glass. Maybe a long time but I really did take time to brush out any creases in the silk. The additional effort paid off in the long run as it took very little sanding the next day to achieve a smooth finish that I was happy to apply the first coat of grey. Pointless getting grey paint on the underside of the model as this one is going to be white so I masked0ff the edges where white meets grey. First coat of grey emulsion and it's time to wait until it's dry enough to polish it with 1200 grit emery cloth. The grey paint makes quite a difference to the appearance of the model and frankly, makes a lovely change from looking at white depron for the past 12 weeks or so. Starting to look more like a Vulcan now Regards Roy Quote Link to comment Share on other sites More sharing options...
lightning 759 Posted February 20, 2016 Share Posted February 20, 2016 looking good andy Quote Link to comment Share on other sites More sharing options...
