IanR Posted January 1, 2016 Share Posted January 1, 2016 Don't fuss, Bob. The postage is £26.40. I reckon you're in front - even with your Irvine spinner! Ian Quote Link to comment Share on other sites More sharing options...
Daniel Brannon Posted January 4, 2016 Share Posted January 4, 2016 Have you had this in the air yet Bob? Desperately waiting for a quick flight review from you before parting with my hard earned. Im hoping it'll have a bit more power out of the box than its little brother Edited By Daniel Brannon on 04/01/2016 14:53:49 Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted January 4, 2016 Share Posted January 4, 2016 Sorry Daniel, but so far I've not had a chance. I did put the wattmeter on it - with the supplied 14*7 I got 460w after the initial 500w startup burst. With an AUW of 5lb 8oz I don't expect anything spectacular from it. 460W is 34A, and it's got a 50A esc fitted so there is room to boost it with a bigger prop if you feel the need. I don't think I have a 15" electric prop to try unfortunately, a 15*7 or 15*8 might be worth a try. Part of the problem at the moment is accessing the field, getting stuck in the mud means a hike up to the farm to beg for a tow from the tractor. Also we are not allowed to fly on our own - it's a Council planning permission condition. Personally I'd be happy to get out flying anything but I also have to be careful with the cold and damp for health reasons and have mobility problems making it difficult carrying anything any sort of distance so hiking with the model from the road is not on the cards. Edited By Bob Cotsford on 04/01/2016 18:12:36 Quote Link to comment Share on other sites More sharing options...
Shearer Posted July 25, 2016 Share Posted July 25, 2016 I have one of these have flown it numerous times its a nice plane but supplied clevis are very brittle and snap I use a 4s 4500 battery that fits no problems at all Quote Link to comment Share on other sites More sharing options...
David Hall 10 Posted June 13, 2017 Share Posted June 13, 2017 Had a few , tail wheel weak I would replace as there are excellent alternatives for £5.00 on E bay, spindle for prop soft ally and not that resilient. U/c good but the box in the air frame that the bolts go into fragile and after a few landings it's a must to tighten( a wooden plate helps a lot ) Motor mounting plate made of thin Ply and I would rec take it out and replace with 3/8 ply .tail of the fuselage vulnerable to break , Sugest carbon rod up its rear as a preventative measure + consider 15 x 8 prop . Not a cheap plane now but does what it says on the tin as a larger trainer. Major problems getting access to replacement fuselage.On line supplier doesn't appear to keep stock . Quote Link to comment Share on other sites More sharing options...
