stuart macrory Posted July 6, 2008 Share Posted July 6, 2008 Hi all,just wondering if anyone out there has converted the multiplex fox for rc .looks a great little model to do so,i have even heard a boy turning it into a little pylon racer!! Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted July 7, 2008 Share Posted July 7, 2008 Hi Stuart There's an article on it in the current (Aug) issue of RCM&E where Andy Ellison does just that........ Quote Link to comment Share on other sites More sharing options...
stuart macrory Posted July 7, 2008 Author Share Posted July 7, 2008 yes thats where i got the idea from,but i was trying to find out the best power setup. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted July 7, 2008 Share Posted July 7, 2008 Ah right - you mean adding a motor? No, Andy just enabled ailerons and elevator for glider only. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 7, 2008 Share Posted July 7, 2008 Any cheap and small brushless inrunner would work OK - easier to fit than an outrunner, but costlier. I think it would end up quite a fast little ship on a small high revving prop. Quote Link to comment Share on other sites More sharing options...
stuart macrory Posted July 7, 2008 Author Share Posted July 7, 2008 Hi timbo,i had a look on brc hobbies website but i dont really have a clue what to go for,what do you think,as you say timbo it will probably be quite fast and thats what i would like to build it for using 2s lipo Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 7, 2008 Share Posted July 7, 2008 3850 version of thisAbout the smallest and lightest I could find after a quick browse around my preferred suppliers - will be happy on a 2s or 3s if you really want fast ! I imagine prop would be around 4 or 5" max - but better check with George Worley ( proprietor ) He does frequent this forum, so may answer on this thread...i will see if I can nudge him Quote Link to comment Share on other sites More sharing options...
stuart macrory Posted July 7, 2008 Author Share Posted July 7, 2008 looks good timbo many thanks.i take it i would not want any more than 3850kv as i see there is 4100 and 4990? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 7, 2008 Share Posted July 7, 2008 nah...would be too thirsty on the old amps....you would need a large capacity battery and they get heavy. PLEASE CHECK WITH GEORGE FIRST THAT THIS IS SUITABLE FOR YOUR PLANS MIND ! Quote Link to comment Share on other sites More sharing options...
stuart macrory Posted July 14, 2008 Author Share Posted July 14, 2008 hi timbo ,i got sorted,i had to go with an outrunner but now my next question is,if the setup i have bought says to use a 9x4 prop for example but i want to use somthing alot smaller like 4 inch how do i know what pitch to go for to get roughly the same flight times as the recommended prop?and if i go with say a 4.5x4.5 apc for example and this is too small for the motor what will be the consequences? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 14, 2008 Share Posted July 14, 2008 the "equivalent" to a 9 x 4 but at 4" diameter would be an over-square prop EG: 4 X 8 or summat...so not really feasible. If the motor you choose has a KV suitable for a 9" prop and you use a 4" it will hardly produce any power at all, and you should use a higher Kv ( lower wind ) motor. The consequences are as above EG: little or no power due to far too low a current being pulled.Big props are better than small props generally in most ways, but obviously there are situs where it s just not practical. Thats really why I suggested an inrunner for such small props. Quote Link to comment Share on other sites More sharing options...
stuart macrory Posted July 14, 2008 Author Share Posted July 14, 2008 hi timbo thanks for reply,the motor is 1500 kv. i was just using 9x4 as an example,i get a prop chart with the motor when i comes hopefully tomorrow or wed,if i have to go with a big prop i will probably just get a folding one as i think this would be my best bet.thanks for your advice. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 14, 2008 Share Posted July 14, 2008 Your welcome...and 1500 Kv is reasonbly high so you may be able to use a nice small prop ! Quote Link to comment Share on other sites More sharing options...
Chris Card Posted July 14, 2008 Share Posted July 14, 2008 Hi Stuart, I grabbed one of the little Multiplex Foxs when they were released as shop samples back in Feb. I haven't added electric power to mine, but converted it to an RC glider instead. With a single cell lipo, Hitec HFS-05MS receiver and 2 5gram servos it tips the scales at 85g AUW. Launching is from the top of my Easystar, using a servo which rotates the Fox to break the grip of a pair of magnets. Best explained in pictures:http://uk.youtube.com/watch?v=L1JjoGbUsPU Quote Link to comment Share on other sites More sharing options...
stuart macrory Posted July 14, 2008 Author Share Posted July 14, 2008 thanks for that that looks a nice little set up youve done,i should have my 1st flight over me by saturday with the motor fitted,im a bit unsure of how much down thrust to give it so fingers crossed. Quote Link to comment Share on other sites More sharing options...
SA Allan Posted July 15, 2008 Share Posted July 15, 2008 Hi here is quite a detailed look at a conversion http://myhobbycity.com/blog.php?b=349 Quote Link to comment Share on other sites More sharing options...
stuart macrory Posted July 15, 2008 Author Share Posted July 15, 2008 many thanks,that link was a good help. Quote Link to comment Share on other sites More sharing options...
Ben Kelly Posted July 17, 2008 Share Posted July 17, 2008 i was thinking of doing this but as i dont know anything about motors and stuff could someone point me in the right direction of a motor and speed controller to add to my Fox. I dont want it to be particulatly fast just be able to pull it round at a comfortable speed. Cheers. Ben Quote Link to comment Share on other sites More sharing options...
stuart macrory Posted July 17, 2008 Author Share Posted July 17, 2008 i will be checking my setup at the weekend weather permitting,watch this space Quote Link to comment Share on other sites More sharing options...
Brendan Bell Posted November 26, 2008 Share Posted November 26, 2008 I want to add a motor and rc to a fox as well. Could someone please tell me where to get some info about the conversion. Quote Link to comment Share on other sites More sharing options...
tam popo Posted November 29, 2008 Share Posted November 29, 2008 Hiya guys - I've done the b/less thing to a Fox with some success. I used an E-Max 2805 originally (125W) and it went ballistic on a 500 2S and folding 6 x 4 prop!!!!! It lasted 5 flights before a vertical dive and burying itself 1ft. down. My new one uses the HXT Blue Wonder motor and 350 2S (same prop) and this gives great flights, as fast a a brushed Stryker!!! The servos (5gm HXT) are mounted in the sides of fuse behind trailing edge of wing and operate rudder/elevon - it is possible to add ailerons (just key in Multiplex Fox in U-Tube for ideas). The lipo sits in a small cut out just behind wing on top of fuse, AR6200 RX and ESC in scooped out cockpit with the motor up front. The next one will be a bipe on a smaller motor (80W) for slowflying etc. If you go to the Giantcod webite (one of RCME's customers) there is a photo section with details of another guys convertion. Quote Link to comment Share on other sites More sharing options...
Brendan Bell Posted December 13, 2008 Share Posted December 13, 2008 Has anyone converted the fox to a 3ch slope soarer? Can i please have some info on the conversion!! Quote Link to comment Share on other sites More sharing options...
tam popo Posted December 14, 2008 Share Posted December 14, 2008 Brendan - if you key in 'Multiplex Fox' in U-Tube there are loas of pics and vids of sloper conversions, and even a Bipe!!! The main ones you need to take a look at are the ones by a group of sloper Flers in Cornwall - great flying etc. Good luck pal..... Quote Link to comment Share on other sites More sharing options...
Brendan Bell Posted December 21, 2008 Share Posted December 21, 2008 Thanks- youtube is pretty good but im looking for like a website or something with pictures of the conversion? Quote Link to comment Share on other sites More sharing options...
Phil_G Posted December 22, 2008 Share Posted December 22, 2008 one version - instructionsanotherheres oneheres anotherand anotheryet anotherenough? My own Fox is buried somewhere one or two of those threads....CheersPhil Quote Link to comment Share on other sites More sharing options...
