chris vernon Posted July 25, 2016 Share Posted July 25, 2016 Hi there, A bit of help is required with regard to the butterfly function on 12fg. I have come from multiplex so bear with me !!!! I have migrated my settings onto my Multiplex tangent electric glider and have test flown it but the butterfly/ crow braking is giving me some grief. I have the function set to the LS slider and have dialled in some elevator compensation within the butterfly function. First flight was interesting with ballooning when crow deployed. Checking the servo movements vis servo monitor has highlighted that the elevator compensation only starts to become active when the LS slider reaches its 50% mid point then it comes in, the flaps % ailerons start to move immediately. The curve is set to EXP1, I have had play with changing it to a POINT curve but confess not to understand it and cannot the desired effect Any help would be appreciated Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 25, 2016 Share Posted July 25, 2016 Does this help?? Quote Link to comment Share on other sites More sharing options...
chris vernon Posted July 25, 2016 Author Share Posted July 25, 2016 Interesting point, I will try it. The servo monitor is without a doubt showing the elevator only coming in at the 50% point and not starting at the zero point Quote Link to comment Share on other sites More sharing options...
