Phil 9 Posted September 23, 2016 Share Posted September 23, 2016 **LINK** I was interested in buying one of these. has anybody here used one. Any feedback would be welcome Quote Link to comment Share on other sites More sharing options...
Matt Jones Posted September 23, 2016 Share Posted September 23, 2016 I can't vouch for that one but I have an older iteration a few years back, tried it once and never again, eventually binned it. Thankfully I'd got it through my old job for nowt. It flexed a lot in use and didn't hold the tool securely. Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted September 23, 2016 Author Share Posted September 23, 2016 oh does not sound very promising Quote Link to comment Share on other sites More sharing options...
Norrland Posted September 24, 2016 Share Posted September 24, 2016 I have had one for a few years and use quite a lot. Not too bad. Comes in very useful for drilling with small diameter drills that very easily break when drilling without a support. The big benefit is that you get a hole that is at the correct angle to the surface, eg 90 degrees. It can be used for simple routing in soft wood like balsa or sanding/polishing. Just don't expect that you are buying a precision tool. Don't get that for just over 30 pounds. Quite a lot of play so take care. As always, use a punch to guide the drill when drilling metal. The Dremel drill is easy to fit and I have had no issues with it coming loose. Quote Link to comment Share on other sites More sharing options...
Former Member Posted September 24, 2016 Share Posted September 24, 2016 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Geoff S Posted September 24, 2016 Share Posted September 24, 2016 I have a very old but good quality pillar drill my dad acquired for me 30 odd years ago. It has a 1/2" chuck that won't go down to very small sizes but I overcome this by putting small drill bits in a pin vice and putting that in my big drill. It works fine but you need to have a big pillar drill I have a mains powered Dremel and though I do use it a lot it's not as useful as I thought it would be when I bought it. Fitting a small chuck rather than the collets makes it much handier. Geoff Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted September 24, 2016 Share Posted September 24, 2016 Looks very nice Percy - I have one exactly the same but it's washed up and in the cupboard... As for drilling, I have a small Clarke mill/drill which is excellent for precision drilling up to 3/8" and acceptable for light milling - undercarriage components, fittings etc. I also acquired a redundant floor standing pillar drill from work many years ago at a bargain price (a tenner) which is useful for any larger work. Edited By Martin Harris on 24/09/2016 11:39:34 Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted September 24, 2016 Author Share Posted September 24, 2016 maybe I will hold of until I can buy something decent. Quote Link to comment Share on other sites More sharing options...
jrman Posted September 24, 2016 Share Posted September 24, 2016 Very tidy workbench Percy! I especially like the tiled back and the chicken in the corner. Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted September 24, 2016 Share Posted September 24, 2016 I bought one of those Dremel workstations about ten or more years ago, and use it regularly, mainly for drilling holes in printed circuit boards. I agree with Norrland's comment about there being play in it, so the hole position needs marking with a centre-punch or with an etched dot in the PCB, to avoid the drill bit wandering before it bites. But it's more precise than any hand-held drill; I wouldn't be without it. Quote Link to comment Share on other sites More sharing options...
