Josip Vrandecic -Mes Posted February 6, 2017 Share Posted February 6, 2017 I'm not the MPX sales agent but worth a look : **LINK** Edited By Josip Vrandecic -Mes on 06/02/2017 21:05:33 Quote Link to comment Share on other sites More sharing options...
jonryan Posted February 6, 2017 Share Posted February 6, 2017 Posted by CJD on 06/02/2017 19:59:54: Hi everyone again,I have bought the Multiplex Easy Glider, can anyone tell me what Lipo is best to run it,the 2s or 3s and what mAh Cheers 2s 1300 in mine, with a 10x6 folder Edited By jonryan on 06/02/2017 21:18:11 Quote Link to comment Share on other sites More sharing options...
Old Geezer Posted February 6, 2017 Share Posted February 6, 2017 Go for the EGPro, love mine (my second, the first one died of a flat battery a couple of hundred feet above the field). No real need to modify it, though I have let some 1.5 x 3mm Carbon strip into the last 40-odd cm of the fuze - both sides and underneath - it wasn't as floppy as the Radian anyway, but it feels better now. I've also got a Solius, but that feels a bit more like a sloper, I fly the EGP more. S'pose I'll eventually end up with a Heron too - it's reported to be the plane the Solius was meant to be. I fly both the Solius and the EGP using a 2200 3S LiPo, c.g. is spot on with the battery pushed as far back as will go in the EGP, the Solius a couple of cm further forward. Quote Link to comment Share on other sites More sharing options...
CJD Posted February 6, 2017 Author Share Posted February 6, 2017 Thanks everyone for your replies Quote Link to comment Share on other sites More sharing options...
PatMc Posted February 6, 2017 Share Posted February 6, 2017 IMO MPX power packs are very poor VFM & 4-Max tend to be a bit overpriced too. I use 3s 2200 lipos on a Turnigy 3542 1000KV motor with Graupner 10x6 blades. The pivot screws of Easyglider Mpx spinner/yoke assembly are further apart than most which extends the prop to 11" dia, in effect giving an 11x6.6 prop. This combo takes about 27A at WOT which is enough for unlimited vertical. A 30 second of power launch takes the model to over 200 mtrs (650 ft) & the battery is good for 6 - 8 launches from a single charge - usually over an hour's air time. The ESC I use is a Jeti 30, which is lower rating than the perceived wisdom suggests but the model's been flying with this setup since June 2009 without problems except when I connected a battery with a reversed polarity connector. I ordered a pair of these from HK the other day as they're at a reduced price & Zippy are among my favorite lipo types Quote Link to comment Share on other sites More sharing options...
