Mirus Build Blog
Mannyroad
Hi Manny
I assume you mean you want to stop flying once you have used 80% of the capacity and stop when there is about 1Ah left in the battery? The ESC will stop once the batteries are near to ‘flat’ and voltage drops down to something like 3.9v per cell I would imagine. To stop at “20% left” you really need to do a few test flights of perhaps 4mins doing your normal flying and then look at how much energy is pumped back in by the charger. If you recharge and put 2500mAh back in after 4min flight you then know that 4mins of flight is about 50% of capacity so you should be OK for about 6 1/2mins.
Given you have a battery of 5Ah you could ‘hope’ for 50A discharge for about 1/10 Hr (6mins) and that would give you about 50A * 20V = 1000Watts. Hence the full battery capacity would give about a 1kW for 6 mins – you are looking for less power at 870W so that gives more time and you won’t be at full-chat all the time so 5 or 6 min flights should be pretty achievable for 80% discharge I would hope.
It would be interesting to see what figures you get from a current meter and rpm meter when running the prop you have. It is said that optimum prop would give (70% of kV*voltage rpm) so for your setup that would give 0.7*740*20 = 10,360 rpm…..
The nice thing about electric is you do have scope to adjust power/rpm/flightime by prop changing and battery changing – 1kW is pretty hectic for a Mirus but it will fly well!
Do keep us informed as I do need inspiration to tackle the 3 Mirus-es I have!
Tony
Hi Tony,
Thanks for your comments, much appreciated. I wasn't aware about optimum prop sizing to achieve 70% kv; I always assumed one chose a prop that allowed the motor to achieve 100% kv rpm or thereabouts, so the info is useful. Thanks. Out of interest why 70%? I would have thought this suggests the prop is oversize and likely to over-draw on amps. not so clearly.
I've read some guys with the same motor are running 11 x 6 props and bigger so maybe my 10 x 6 will rev too quickly. Might need to source a 10 x 7 or 8 to 'push' the motor.
But yeas, will check it out with my watt meter and tacho and see what I get.
Hi Manny
Not sure how scientific the 70% is but I think the kV figure is motor 'no load' speed so 70% gives some sort of efficient loading without bogging it down too much I imagine. Let us know what power figures you get and how early flights go. I hope to get back to models shortly but have just finished rebuilding a new (1963) lathe and have bought a new bike (1975 Trident T160) so need to clear out some stuff from garage before I can begin - better clear a couple of bikes and the old lathe for a start methinks!
Good luck.
Tony
Mark, I will i'm sure, but gently gently at first methinks, hee hee.
Tony, had one of those Tridents back in 79. A Hyde conversion. Nice. Love the Trident.
Not flown my Mirus yet as I'm busy sorting out damage to my custom bobber (Indian Larry Grease Monkey replica), after dumping it down the road on a left hander last month (on a test run after taking over two years to build it!!). But I'll get both of them flown within the next two weeks and will update this thread with how it goes.
Thanks Alan. Repairs are in progress and hopefully (if my mate pulls his finger out and gets on with repairing the tank) I should be back on the road in a few weeks. Sorting this out has stopped me finding some time to get the planes aloft; hopefully that will get back on track soon too.
The motor is an S&S 84" performance motor. Rare as hen's teeth.
  • 6 months later...
  • 5 years later...
This was posted earlier in the thread. It shows the C of G behind the aft wing bolt, the question is how far behind, there is no scale on this plan? It also assumes the rear wing bolt on your model is true to plan! Perhaps you will just have to wait for someone with a Miras to post.
Miras Plan.pdf
Good luck with the maiden, it should be exciting 😁
Edited by Piers Bowlan
