Electric Retracts poser
Just started a Mosquito build using the plans from Ivan Pettigrew and ordered up a pair of retracts from Hobbyking.
Can anyone out there explain why the holes for the retract leg are sized at 3mm?
8 AWG is 3.26mm
10swg is 3.251mm
1/8 inch is 3.175mm
I know you can get 3mm piano wire but it is abnormally expensive.
Easy enough to drill out but an unnecessary complication???
Just wondering.
Robin
Essential to bend in this case according to Ivan on his plan to avoid breaking the retracts. He makes quite a point of it in his build blog so who am I to ignore the advice.
Quite a complicated set of bends as well. Would have been a lot easy if I could have put my hands on my wire bender!!!!!
Thanks for the comments.
