Colin Leighfield Posted May 21, 2017 Share Posted May 21, 2017 i'm going to Shawbury today and thought it would be good to have something to accompany my little Caudron. I knocked this up from scratch in just a few hours yesterday. Somewhat crude, all Depron, 3mm Aero quality and 6mm grey. Wing leading edge and spar 3mm hard balsa. Parkzone P51 geared motor, AR6410 Spektrum rx, 1s 160mah Lipo. Crude, wings are definitely "aero-elastic", but it weighs 42gms only with battery, 31"span, 115 sq.ins. area, wing loading 2ozs./sq.ft. Should be good for a laugh. If it works I'll tidy it up. Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted May 21, 2017 Author Share Posted May 21, 2017 It flies a treat! After a hairy first flight while I sorted out the trims and elevator throw, it settled down and flew beautifully. As you'd expect with such a low wing loading it can fly very slowly and as the afternoon went on, I progressively got the hang of it. Towards the end, there were a lot of planes in the air simultaneously and it was getting hairy. I had an air to air with an Albatros DV that brought us both down, fortunately undamaged. Must be the first time that a Wellesley ever shot an Albatros down, WW2 meeting WW1! Danny Fenton was there and here he is with John Minchin, who does a lot of organising to make indoor flying at Shawbury possible. Danny kindly took for me more pictures using my IPhone, here you can see the Wellesley in its element. Great fun, over now until September. Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted May 21, 2017 Author Share Posted May 21, 2017 Just realised that I had left this off the previous post! John and Danny. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted November 28, 2017 Share Posted November 28, 2017 Hello Colin where did the c of g end up on your model. i am building a bigger version and it would help with the positioning of my battery and servos. thanks in advance Tony B Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted November 28, 2017 Author Share Posted November 28, 2017 Hi Tony. You need to be careful with this. Mine is a very light Depron indoor flyer and it needed to be at 20% of mean chord. I have also enlarged the tailplane slightly. Bear in mind that with the very short moment arm the c of g is probably safer a bit forward. Also thinking that the original prototype of the full sized plane was destroyed when it got into a flat spin while Jeffrey Quill was flying it. He couldn’t get it out and had to bail out. Therefore personally I wouldn’t go further back than 25% of mean, not root, chord. Only my opinion of course. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted November 28, 2017 Share Posted November 28, 2017 thank you kind sir. it will be an interesting flier i expect. Tony B Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted November 28, 2017 Share Posted November 28, 2017 Depron Col, Looks fun Colin, very good. Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted November 28, 2017 Author Share Posted November 28, 2017 John, it’s easy, cheap and a lot of fun. Tony, that looks great mate, I started to draw up a big one a while ago. A couple of degrees wash-out on the wing might not go amiss. It’s a very efficient wing and should fly well. Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted November 28, 2017 Author Share Posted November 28, 2017 Photo taken before the trip to Shawbury on 19 November. The Wellesley followed the Fairey Long Range Monoplane in the Long Range Development Unit anfew years later. The chuck glider Avro 730 flies well and is the basis of an idea for a Depron twin EDF. Edited By Colin Leighfield on 28/11/2017 23:53:02 Quote Link to comment Share on other sites More sharing options...
