Spektrum DX6 and ST Salto
John Bisset
  • 1 year later...
Hi Shaun.
I use exactly the same battery as Peter, entirely agree with his comments.
Like Peter I haven't measured the thrust, but it is enough thrust for a hand launch from stationary in under five knots wind - or for a ground launch on concrete in less than thirty feet.
Most of my level circuit flying is done at around 30% power, so plenty to spare for climb and lots of duration.
The hardest part is the descent to land, since drag is low - quite a fast glide too. I find that if I can set the throttle so the fan stays out but isn't running, that gives a nice bit of extra approach drag, Am tempted to modify to add airbrakes, but then as a full-size glider pilot I do like those - and since I used to have a Libelle 301, the Salto is a source of reminiscence!
John
