peter haywood 1 Posted September 8, 2017 Share Posted September 8, 2017 Gentlemen, Ithank you all very much for your advice and guidance on the radian glider. I have already trawled through shops and e stores, stock is shown of parts but I go to order it comes up as on back order.Cymaz you directed me to a website which said it i now defunct. Sorry if it is a bit daft but I would rather try to get an airframe instead of buying a different plane. I have had more sucess flying this than anything else,as I am in the learning stage of flying it had given my confidence a massive boost. Again I thank you Gentlemen. Quote Link to comment Share on other sites More sharing options...
Ray Farrimond Posted September 8, 2017 Share Posted September 8, 2017 Don`t know if this is any help it`s in the US. https://www.amainhobbies.com/parkzone-radian-bare-fuselage-pkz4767/p52507 Ray Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted September 8, 2017 Share Posted September 8, 2017 In fairness to yourself Peter, to fly a Radian well, does take some skill and anticipation, and to land it well also involves quite some skill keeping the wings level, so I suggest you could easily master another motorised glider as the Radian suited you so well What the Radian does give you is that time to think and maneuver as you can " linger " a while and change your mind as it does give you that extra bit of thinking time as it floats Other floaters can give you this. If you think further down the line, as you progress even more, and time passes, 1 year maybe 2 years, and you will have moved on. Don't let the lack of a Radian hold you back now, just carry on flying an intermediate model to keep you going forward. Just an opinion Radian spares http://www.tjdmodels.com/rc-aircraft-spares-parkzone-radian-c-12_34_101.html Edited By Denis Watkins on 08/09/2017 21:10:07 Quote Link to comment Share on other sites More sharing options...
Tony Harrison 2 Posted September 9, 2017 Share Posted September 9, 2017 Posted by Denis Watkins on 08/09/2017 21:06:34: ...to fly a Radian well, does take some skill and anticipation, and to land it well also involves quite some skill keeping the wings level...What the Radian does give you is that time to think and maneuver as you can " linger " a while and change your mind as it does give you that extra bit of thinking time as it floats.. Certainly true of my Radian Pro: even under supervision by a highly experienced flyer I crashed mine (steep diving turn into the ground) and had to re-attach the tail, fit a new prop; more recently I tried flying it solo (no-one around to embarrass me) and managed a flight of, oh, maybe 5-10 seconds - another wild steep diving turn immediately following take-off in near windless conditions, causing serious damage that frankly I cannot be bothered to try and fix. I am far more attached to my first self-build, an old fashioned sort of trad-construction electric glider, 6' span, which is genuinely "floaty": I've only crashed it once, easily re-built the nose (it seems tougher than the polystyrene Radian), flew it under supervision very successfully and enjoyably. I'd gathered originally that these ARTF poly jobs were much gentler and easier but this hasn't been my experience - maybe the Radian Pro is just crap? Anyway, I enjoy building my own hugely, nearly finished a high-wing trainer (1980s kit from C.Goldberg) and sort of started a big DB Tiger Moth. Trouble is, I dread the thought of crashing my new trainer! Maybe I should just build the things and let others fly them... Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted September 9, 2017 Share Posted September 9, 2017 Ailerons Tony, with authority too. Like the Passenger Jet that took you on holiday, take care as much as possible to turn gently banked while you gain confidence, nothing over 10° Most aircraft on their side are difficult to control, so preplan in your head and keep saying throttle back wings level Calm the beast, wings level then feed in the motor again If it becomes a bucking bronco Throttle back, wings level, nose up to level flight, regain control Edited By Denis Watkins on 09/09/2017 13:12:15 Quote Link to comment Share on other sites More sharing options...
Tony Harrison 2 Posted September 9, 2017 Share Posted September 9, 2017 Thanks Denis. I tried to take off gently in a straight line, to get out there in a steady climb before anything adventurous like turning - however, the R.Pro had different ideas and banked violently right and down... rgds Tony Quote Link to comment Share on other sites More sharing options...
steven rennard 1 Posted September 9, 2017 Share Posted September 9, 2017 Hi Peter. I was just reading your post and realised I may have what you need. I purchased a Parkzone Radion pro from a fellow member of my club. He is a very proficient glider pilot, and as for me, I flew it once and decided it wasn,t for me. Its been sat in my dormer for about two years doing nothing. Steven. Quote Link to comment Share on other sites More sharing options...
Tom Thomas Posted September 9, 2017 Share Posted September 9, 2017 You should google the number for spire models in Salisbury, last time I was there he had the radian. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted September 9, 2017 Share Posted September 9, 2017 Posted by Tony Harrison 2 on 09/09/2017 13:27:08: Thanks Denis. I tried to take off gently in a straight line, to get out there in a steady climb before anything adventurous like turning - however, the R.Pro had different ideas and banked violently right and down... rgds Tony This model sounds like a handful with a mind of its own! I have a Radian X/L which is a complete pusycat and very relaxing to fly. (I did stiffen up the rear fuselage with some carbon fibre strips which makes control a little more positive as it was a bit disconcerting watching the whole tail wiggle with rudder input! Better now. Quote Link to comment Share on other sites More sharing options...
