Andrew Moore 7 Posted September 22, 2017 Share Posted September 22, 2017 Can someone recommend a decent quality Gyro for Futaba gear/fixed wing aircraft ? Need one that works a bit like the good gear on the E-Flite Apprentice S 15e model - 6-axis, flight stability etc Don't really know where to start with this one Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted September 23, 2017 Share Posted September 23, 2017 It is really very simple Andrew, and you can keep your Futaba gear as add on stabilisers can be connected to your receiver via 4 male to male extension leads. 4 leads are for on/off, Aileron, Rudder, Elevator There is very little room in most foamies but if used, the stabiliser is fitted horizotally on the floor of the model and jump leads to your existing receiver. These are 3 axis stabilisers and micro stabilisers are available Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted September 23, 2017 Share Posted September 23, 2017 If you just want one to stablise the model in windy weather then something like this or this would do the job connected to your receivers, or this one that is FAAST compatible , but non of these have the autolevel function that is fitted to the Apprentice. You could do this with a flight controller, eg CC3D which has a fixed wing mode, but you would need to spend a bit of time configuring and setting it up. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted September 23, 2017 Share Posted September 23, 2017 Franks Orange suggestion will be least intrusive addition to your gear, No matching up or moving away from Futaba Just fit the Orange unit between your servos and receiver via male to male leads Quote Link to comment Share on other sites More sharing options...
Andrew Moore 7 Posted September 23, 2017 Author Share Posted September 23, 2017 Thanks guys - very informative. Really looking for one with an Autolevel function like the Apprentice - going to have to start searching a bit more Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted September 23, 2017 Share Posted September 23, 2017 hobby eagle A3 super ii is one I used and if found it to be great. it does everything the spectrum as3x safe system does. I use a futaba 8FG transmitter Edited By Phil 9 on 23/09/2017 18:17:52 Quote Link to comment Share on other sites More sharing options...
BackinBlack Posted September 23, 2017 Share Posted September 23, 2017 Eagletree Guardian. Slightly more expensive but has all the ASX3 functions and more including auto level. Quote Link to comment Share on other sites More sharing options...
Andrew Moore 7 Posted September 24, 2017 Author Share Posted September 24, 2017 That Hobby Eagle A3 2 seems to have all the functionality I'm looking for and cheap - thanks again Quote Link to comment Share on other sites More sharing options...
