gangster Posted October 24, 2017 Share Posted October 24, 2017 ok guys just want to bounce some ideas off you. In over 40 years of radio modelling I must be one of the few people never to own a WOT 4 Now in a sudden whim I decided to build one. I have a plan for the original mk1 produced by Yesterday's Aeromodeller plans service. I also have plans for a suitable wing. The original 1970s wot 4 was not a kit but a plan pack as far as I can see Now the fus is built and I was about to assemble a wing (I have some ribs to make up a built up wing) The original had foam wings. Out of the blue I was given a complete finished wot4 wing (unflown ) wonderful until I discovered that the chord at the centre was about an inch larger than that of either my plan and the built up wing plan which are 11inch So none of the bodges I have considered seems satisfactory Cannot cut an inch off the trailing edge without the torque rods fighting the bulkhead although separate servos could alleviate this even winning a little bit on the leading edge trailing edge and fus seems a bodgevtoo far Any ideas or should I just get on and build the ribbed wing Quote Link to comment Share on other sites More sharing options...
iqon Posted October 24, 2017 Share Posted October 24, 2017 if you did the fuz and are able to do the wings then start building again. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted October 24, 2017 Share Posted October 24, 2017 hello gangster...build the ribbed wing and keep the later one for a spare....the MK1 is different in a few respects to the later Wots... ken anderson...ne..1..... Wots dept Quote Link to comment Share on other sites More sharing options...
Keith Evans 3 Posted October 24, 2017 Share Posted October 24, 2017 Hi Gangster ,it is not impossible to lengthen the rear of the fuselage wing seat to take the wider wing .I did this mod a number of years ago and the plane flew like a Wot 4 should . Regards Quote Link to comment Share on other sites More sharing options...
gangster Posted October 24, 2017 Author Share Posted October 24, 2017 Hi guys. Thanks for your input. Decided to think on it during a long walk in the forest with the dog. Both options are feasible but I have decided to build the wooden wing. Not only is the chord greater but the profile is also different so the seat will need reshaping. It will probably be quicker to build a wooden wing. Especially as against my better judgement I decided to follow the plan and put that nasty spruce longeron in Quote Link to comment Share on other sites More sharing options...
Plummet Posted October 24, 2017 Share Posted October 24, 2017 I built one of these with the built up wing and it flew beautifully. (That is, until I was distracted, it flew too far away and I lost orientation.) Plummet Quote Link to comment Share on other sites More sharing options...
Former Member Posted October 24, 2017 Share Posted October 24, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
