Tom Thomas Posted October 28, 2017 Share Posted October 28, 2017 Cheers Richard Quote Link to comment Share on other sites More sharing options...
DaveyP Posted October 28, 2017 Author Share Posted October 28, 2017 Thanks for the replies, I've just ordered a lemon 6ch rx. Interestingly though the link takes you to a lemon rx at £16.99, but going direct to the ebay site the same rx is only £12.99 free p&p.......... Quote Link to comment Share on other sites More sharing options...
peter harvey 1 Posted October 28, 2017 Share Posted October 28, 2017 The difference is that the dearer item has a diversity aerial which is essentially two different processors and it uses the best signal, this means that it has the reception that you would expect if you had a satellite receiver attached, but don't worry it will still work well provided you still have line of sight and are less than 1000m high I have used both and had no problems and our field is near Stockport and a large micro wave transmitter , we had quite a lot of glitching occurring when most people were on 35meg, and some when using orange, but not now we are using Lemon Good Luck Peter Quote Link to comment Share on other sites More sharing options...
peter harvey 1 Posted October 28, 2017 Share Posted October 28, 2017 just ordered 2 more 6 ch receivers with diversity from Lemon on line shop costing £27, their website is Lemon Rx Online Shop (Xenon Electronics Limited) delivery is usually 7/10 days Peter Edited By peter harvey 1 on 28/10/2017 11:35:17 Quote Link to comment Share on other sites More sharing options...
Daithi O Buitigh Posted October 28, 2017 Share Posted October 28, 2017 Two aerials mounted at 90 degrees to each other - seemples :D Quote Link to comment Share on other sites More sharing options...
gangster Posted October 28, 2017 Share Posted October 28, 2017 Diversity antennae are a common feature on many different types of radio system. Particularly at higher frequencies although some car radios use them for VHF Not just model but serious professional links including microwave links. The idea is if there is a reason for one aerial to get a fade in signal i.e. Beam diffraction or on our case the model is moving all the time the second aerial hopefully takes over. So if your rc receiver has more than one aerial or a satellite receiver it could be described as a diversity system That is why we are told to separate the aerials and put them in a different orientation than the other. Quote Link to comment Share on other sites More sharing options...
